BMW rectangular pucks - ? ? ?
Old Jun 8, 2008 | 11:16 AM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Originally Posted by WHT
I use the round BMW pucks and keep them mounted 24/7. No problem at all since they extend only about 1/4-inch below the rocker panels. If these snag on anything your rocker panels would have been toast. They are the same thickness as the frame/rocker rails I installed and together provide excellent rocker panel protection.
I also purchased a set of the square pucks, but didn't use them because they don't fit as well as the round pucks and are too thick IMO.
I have been using the round pucks as well with no problems. I never remove them. Most all good tow drivers knows that the pucks have to be removed for tie down. If he or she does not; you may want to find
a better Towing Company.
Old Jun 9, 2008 | 10:34 AM
Homer3D's Avatar
Homer3D
Originally Posted by csun213
Can the round ones also be left on the car? I like them better since you can not see them when left on the car.
Yup, I have been driving with them on for a while. Never had a problem. I forget they are even there.
Originally Posted by YeeeeeHaw
Like it a lot Is installation same as the rectangular ones? What's the dimension?
Please send links.
Yup, installation is the same. Not sure on the dimensions
