Vert Top Problem
Old Jun 7, 2008 | 11:22 PM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
Default Vert Top Problem
Has anyone else had a C6 Vert soft top not go all the way up? It seems that the hydraulics are either low or leaking pressure. The glass part of the top wont raise high enough for the lid to close and allow the completion of the cycle..
Is this a quick fix of some sort or a dealer call???
Old Jun 8, 2008 | 01:09 AM
Rocketmanwpb's Avatar
Rocketmanwpb
I have not looked at the pump unit in the vett but there should be a reservoir. Check the reservoir and make certain it is full. You may have a hydraulic leak. Check for damp areas. Check the locations the hoses connect, you may find the leak there.
My 98 Camero pump went out and I was a be to rebuild it using O rings from the hardware store.
Use the correct fluid when replacing.
Old Jun 8, 2008 | 10:24 AM
C2C6Z06's Avatar
C2C6Z06
Thanks Rocketman. I sorta narrowed it to a hyd problem of some sort and went looking for the pump that the owners manual says is in the engine compartment, passenger side. There is even a diagram of the pump with several pressure lines going to the "front" side....
Well, I know my eyesight is failing, but for the life of me I cannot find that pump:o I have identified every component on both sides of the engine and cannot find the pump.
Anyone have a pic?
PS - boy do I feel stupid right now
Old Jun 8, 2008 | 10:30 AM
JJC5's Avatar
JJC5
The pump is under the tonneau cover behind the passanger seat, not the engine compartment. You'll have to pull back carpet to see it. There is no reservoir either. You can release the pressure by turning the large allen bolt and the wrench is supplied. I recommend releasing the hydraulic pressure and then retighten the bolt to see if that helps.
Old Jun 8, 2008 | 10:46 AM
C2C6Z06's Avatar
C2C6Z06
Thanks, I thought I was going MAD not finding the pump where the manual said to look
Old Jun 8, 2008 | 11:02 AM
C2C6Z06's Avatar
C2C6Z06
Just went out, found the pump (thanks to JJC5!) and discovered the pressure bolt was about an 8th turn loose, just enought to fail when needed the most. BTW, there is also a reservoir. I need a little fluid when I find the right type..
Gotta love this forum and the helpful members!!!
To Vert Top Problem
