Instrument Panel Dimmer Switch
Old Jun 12, 2008 | 08:19 AM
Softballnut's Avatar
Softballnut
Default Instrument Panel Dimmer Switch
Is there a trick to getting the IP dimmer switch to work? I turn it counterclockwise to try and dim, but it has no apparent effect? Thank you.
Old Jun 12, 2008 | 08:25 AM
tscales's Avatar
tscales
St. Jude Donor '07
It doesn't dim very much, which I find annoying. On my C5, I could turn off the entire panel, which was fine, since I had the HUD. On the C6, even the dimmest setting is pretty bright.
Old Jun 12, 2008 | 08:35 AM
davanz's Avatar
davanz
Try this. With engine running and headlights on, turn the dimmer **** to left (to dim), or right and HOLD for a few seconds. On my o6 there is a time delay for some reason, and as stated before the dimming range is not much.
Old Jun 12, 2008 | 10:30 AM
Vette_DD's Avatar
Vette_DD
Look at the indication just below the switch. You should see a painted white band. Whichever end of the band has the most white paint, that's the direction you need to turn the dimmer switch and HOLD it to brighten. Turn the opposite way and HOLD to dim it.
Old Jun 12, 2008 | 10:34 AM
danl72's Avatar
danl72
Old Jun 12, 2008 | 01:10 PM
Softballnut
Thank you all.
Old Jun 12, 2008 | 08:20 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Yep, I had the exact same question. It just didn't seem to dim much. I could see a difference when I turned up the switch. I will try the running engine/headlight on trick. Thanks.
Old Jun 12, 2008 | 08:36 PM
Mad*Max's Avatar
Mad*Max
To Instrument Panel Dimmer Switch
