Front Plate Solution W/pics
Old Jun 15, 2008 | 02:18 PM
g.smith's Avatar
g.smith
Default Front Plate Solution W/pics
Here is what I decided to try and see how it holds up! Sort of copied the idea from a Forum Vendor! I just couldn't see paying that much for something I could do for about $2.00.
I simply cut myself two aluminum L brackets and mounted them on the front plate. While I had the plate in my hands, I bent it to conform with the front of the car and added foam to the bottom in case it contacted the car.
[IMG][/IMG]
Then I put some of that super sticky two face tape on the bracket and trail fitted it before mounting it. I cleaned and removed the wax from the mounting points then I stuck it on the car, trying to center the plate to the car!
[IMG][/IMG]
Here is what it looks like, I'm I happy with it "NO"
Do I like it as much as some of the brackets being sold on this Forum "Yes".
Do I have other options if I change my mind, "yes".
I can always take it back off with a little effort and no damage to the car.
[IMG][/IMG]
[IMG][/IMG]
Old Jun 15, 2008 | 02:19 PM
danl72's Avatar
danl72
Good idea.
Old Jun 15, 2008 | 02:20 PM
Tri-Tip's Avatar
Tri-Tip
I guess it makes the best of a bad situation.
Old Jun 15, 2008 | 02:26 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Jun 15, 2008 | 02:27 PM
Top Flight Reproductions's Avatar
Old Jun 15, 2008 | 02:42 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
But it's still like a wart on the nose of Miss Universe. I'm sure glad we don't have to have front plates in Florida!
dvilin's Avatar
dvilin
Creative and does the trick.
Old Jun 15, 2008 | 02:47 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Originally Posted by Top Flight Reproductions
Oh well...what's ONE lost sale.
Old Jun 15, 2008 | 02:49 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Nothing like cheap and easy
Old Jun 15, 2008 | 02:50 PM
VET4LES's Avatar
VET4LES
Looks good, I hope it stays on.
Old Jun 15, 2008 | 02:52 PM
g.smith's Avatar
g.smith
Don't worry, He already got some of my money and will surely get some more of it!!!
He is a great vendor and has always treated me right!!
Old Jun 15, 2008 | 02:55 PM
Thanks Gary
Old Jun 15, 2008 | 03:03 PM
g.smith's Avatar
g.smith
I hope so too!
That stuff is not just regular two face tape, super strong and it is the same thing that is recommended here for mounting the z06 splash gaurds on our c6's. McMaster Carr sells it and it is some good stuff!
Old Jun 15, 2008 | 04:19 PM
gbgary's Avatar
gbgary
pretty good. you need to put the bottom foam on the car, not the plate though. if you don't it'll get scratched pretty quick.
Old Jun 15, 2008 | 04:29 PM
keyplyr's Avatar
keyplyr
Looks great (for what it is.)
I came up with something similar just in case I had to get a ticket signed off. I took the large suction cups from the V1 package that I wasn't using and stuck the **** into the upper holes in the plate, the small suction cups into the lower holes. Sticks on the nose without scratching. Works perfect for temporary use; would stay on under daily driving conditions.
I'll post some pics when I think of it.
Old Jun 15, 2008 | 06:28 PM
STEVE MC's Avatar
STEVE MC
Great idea. You could have taken it one step further by making it removable.
Cut two more squares of aluminum, then drill a body hole with a countersink into the center. Now drop a flat head screw in with some Locktite superbond. Once it dries, bolt every thing together with some wing nuts then use your 3M tape to secure the bracket to car.
This would make it removable by unscrewing the wing nuts.
Just a thought.
Old Jun 15, 2008 | 07:19 PM
CHARMR's Avatar
CHARMR
Good Idea. I'm moving to Texas and while there this past month I did not see a single corvette with the front plate! Not a single one and I saw at least 30 or so vettes in 3 weeks. G.Smith your idea is just about what I had in mind and probably better. The other suggestion from Steve is what I think I'll do too. For about $10 American, I can have an equivalent front support that rivals a forum vendors solution.
To Front Plate Solution W/pics
Old Jun 15, 2008 | 07:23 PM
CHARMR's Avatar
CHARMR
Hey, now this is a good solution too. In addition, you could use a piece of soft cord/thread/something to fasten to the plate and if the suction cups came off the cord would catch the plate. Anther good solution. Show some pics.
Old Jun 15, 2008 | 07:27 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
AGREE! but you've done the best you can.
Suggestion: put some tape or something behind the lower lip of the license plate (if you haven't already). Otherwise, the constant vibration of the plate on the painted bumper will take off the paint.
Old Jun 15, 2008 | 07:50 PM
sixdogs's Avatar
sixdogs
I agree; the vibration will wear a mark into the paint. I have done it.
