A6 Fluid help
Jun 20, 2008 | 02:44 PM
A6 Fluid
For those of you that change your A6 fluid
Jun 20, 2008 | 03:33 PM
Jun 20, 2008 | 04:39 PM
From: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
Jun 20, 2008 | 04:52 PM
If it is like the A4 transmission, the transmission has to be filled and then the car started to getthe fluid to the correct level. Since the fill hole is on the side of the transmission, that means you have to be under the rear of the car with the engine running to properly fill the transmission and the car has to be level when filling it.
Jun 20, 2008 | 04:53 PM
Quote:
Originally Posted by
RogerC6
Dexron II.
just spoke to a tech he advised GM Dexron VI only, so that's the route I'm going to go.
I wouldn't go Dex II if I was you you'll fry that trans
Jun 20, 2008 | 04:54 PM
RogerC6
Dexron II.
Is the Dexron II for the A6? Also anyone change out the fluid to run a synthetic like Royal Purple?
Jun 20, 2008 | 05:00 PM
Spearfisher
You are correct is Dexron VI for the C6.
Jun 20, 2008 | 05:01 PM
Spearfisher
For those of you that change your A6 fluid, what do you use and what has been your experience doing it.
I would use GM Dexron VI.
I would not use Dexron II.
