Help with Map Light s
Old Jun 30, 2008 | 07:28 PM
marathon's Avatar
marathon
St. Jude Donor '09
Default Help with Map Light s
I purchased LEDs to replace my interior lighting. Having a heck of a time removing the map light bulbs. Any suggestions?
Old Jun 30, 2008 | 07:47 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Having never felt the need to remove my bulbs I can't offer very much. The service manuals don't offer much either:
1. Remove the lamp lens from the mirror housing. Pry carefully with a small, flat-bladed screwdriver at the rear edge (1) of the lens, furthest from the windshield.
2. Remove the bulb from the socket.
Old Jun 30, 2008 | 07:56 PM
marathon's Avatar
marathon
St. Jude Donor '09
Thanks Paul, I have removed the lens on both sides but the bulbs will not budge.
Old Jun 30, 2008 | 07:59 PM
GMautotech's Avatar
GMautotech
I used a paper towel and carefully used a pair of needle nose pliers. Use a flashlight to see which way they are seated in the sockets and then just work them back and fourth.
Old Jun 30, 2008 | 08:41 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
The best way I found it the old "Chinese finger" trick. you need to find a piece of rubber tubing that fits tight enough to just fit over the blub, push it on and pull down quick, the bulb will come with it. Remember the led’s are polarity sensitive so they only work one way
Old Jul 1, 2008 | 10:05 AM
marathon's Avatar
marathon
St. Jude Donor '09
Thanks guys, I finally removed them with a small flat blade screw driver which was suggest by another member but it was a struggle. However, while prying the driver side out the on/off button and part of the switch contact fell out. Not sure how to get this back in place.
Old Jul 1, 2008 | 10:37 AM
Pipedreams's Avatar
Pipedreams
The very last tool I would use us a screwdriver, not sure how to get that back in
Old Jul 1, 2008 | 11:08 AM
socalenergyman's Avatar
socalenergyman
OMG how hard did you pry on it????? I have done three of my friends map lights with with a small flat head,works great,about a 3 second job
Old Jul 1, 2008 | 11:12 AM
danl72's Avatar
danl72
Cool. Let us know what they look like.
Old Jul 1, 2008 | 11:43 AM
marathon's Avatar
marathon
St. Jude Donor '09
The flat blade worked just fine. I knocked the switch loose trying needle nose yesterday. The reflector moved and that's what caused the switch to fall out.
To Help with Map Light s
