Changing DRL's
Old Jul 4, 2008 | 09:39 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Default Changing DRL's
I searched and searched and can not find the thread that at one time explained this with pictures (I did find a couple that simply described it). My passenger amber light is out (have the replacement). I have turned the tires and removed the access panel in the wheel well. I can even put my hand on the proper light.
I can not push it in, pull out, or turn the holder.
Any advice would be appreciated.
Thanks!
Old Jul 4, 2008 | 09:53 PM
2LT-Z51's Avatar
2LT-Z51
it is super hard to turn.... it turns counter-clockwise.... the gasket sticks....
pics of headlight assy
Old Jul 4, 2008 | 10:20 PM
maxp's Avatar
maxp
I replaced both bulbs with the PIAA brights and the drivers side was extremely tight. I just kept at it and it finally turned. good luck
Old Jul 4, 2008 | 11:09 PM
Tom_Slick's Avatar
Tom_Slick
Try this... http://forums.corvetteforum.com/show...m_slick%2C+drl
I did PIAA's myself... Blue to white.
The passenger side was twice as hard to remove...
Old Jul 5, 2008 | 01:17 AM
cclive's Avatar
cclive
On mine, drivers side was easy and passenger was so tight that I thought it was installed wrong, but finally came loose and is fine. Frosted my bulbs with silver paint:
Old Jul 5, 2008 | 01:55 AM
Low12s's Avatar
Low12s
Did you do this with the tire on or off?
Old Jul 5, 2008 | 02:12 AM
jabez's Avatar
jabez
It took me about 45 minutes to unscrew the socket and about a minute to replace the bulb and put the panel back on. There is a little lever that you push and turn at the same time to remove the socket and the wire connect to the socket makes it really tight.
Look at link below. It might help you with the pics provided.
http://www.corvetteactioncenter.com/...d.php?t=102281
Old Jul 5, 2008 | 09:42 AM
ufso's Avatar
ufso
Don't Forget To Replace Them "both!!!" If You Don't, The Old One Will Be Dimmer Than The Newer One.
Old Jul 5, 2008 | 10:53 AM
maxp's Avatar
maxp
tires were on
Old Jul 5, 2008 | 12:56 PM
Low12s's Avatar
Low12s
Thanks Jabez! What I was missing was the tab that you push in. I will try again this morning.
Old Jul 5, 2008 | 01:29 PM
danl72's Avatar
danl72
To Changing DRL's
