damn...first problem with the c6 :(
Old Jul 9, 2008 | 03:00 PM
StoplightWarrior's Avatar
StoplightWarrior
Default damn...first problem with the c6 :(
Noticed yesterday, when it was REALLY hot here (like 100+) that my c6's thermometer read 84 degrees. Didn't think much of it until I went out again last night and the thing still said 84. Today, it is HOT again, and the thing still says 84, without change. Is this a common problem? Is it worth taking the car in for this minor thing?
Old Jul 9, 2008 | 03:02 PM
JJC5's Avatar
JJC5
Check your owners manual. It's normal. You need to drive at least 10 minutes at a speed above (some number, I think 25). You'll see it change. It has to do with not confusing the climate control.
Old Jul 9, 2008 | 03:04 PM
StoplightWarrior
Ok, that might be right, then, since it has been SOOOO hot the last few days, and my trips have been short (~10min). I'll check it out.
Old Jul 9, 2008 | 03:05 PM
Vette_DD's Avatar
Vette_DD
It doesn't update automatically. Here's what your 2008 owner's manual says on pages 3-28 and 3-29.
There is also a sensor located behind the front bumper.
This sensor reads the outside air temperature and
helps to maintain the temperature inside the vehicle.
Any cover on the front of the vehicle could give a false
reading in the temperature.
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 12 mph (19 km/h) for
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation.
"When all else fails, read the instructions."
Old Jul 9, 2008 | 03:10 PM
jmagilto's Avatar
jmagilto
your temp guage may be wet. I have seen mine read wrong for a few hours after washing the car...
Old Jul 9, 2008 | 03:13 PM
JJC5's Avatar
JJC5
Don't feel bad about not reading the instructions. Who would think that you need to read instructions about how to read outside air temperature? I posted the same thing when my Vette was new. By the way; it DOES update automatically.
Old Jul 9, 2008 | 03:16 PM
danl72's Avatar
danl72
Old Jul 9, 2008 | 03:38 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As has been indicated if the vehicle has not moved, or not travelled very fast or very far since the last reading it is perfectly normal.
The radio displays the outside air temperature value that it receives from the HVAC control module through a class 2 message. The scan tool has the ability to update the displayed ambient air temperature. The outside air temperature value is displayed or updated under the following conditions:
Condition
Display
At start up with the engine OFF more than 3 hours
Displays actual outside temperature
At start up with the engine OFF less than 3 hours
Displays last stored temperature
Vehicle moving above 16 km/h (10 mph) for 5 minutes
Updates temperature display at a slow filtered rate.
Vehicle moving at 51 km/h (32 mph) or greater for 2.5 minutes
Updates temperature display as rapidly as possible.
When the sensor reading is less than the displayed value.
If you need to verify that it is working or if you have a need to instantly update it you can
Press the Front Defrost, Rear Defog and fan up buttons simultaneously.
and it will update the temperature display instantly.
Old Jul 9, 2008 | 03:54 PM
StoplightWarrior
Condition
Display
Old Jul 9, 2008 | 04:37 PM
mongooseC6's Avatar
mongooseC6
Mine is parked inside the garage and the thermometer does the same thing. It will change as soon as you start driving. No problem.
Old Jul 9, 2008 | 05:04 PM
cclive's Avatar
cclive
Condition
Display
This last part is important and is not in the manual....I use it all the time and it works great! Thanks Talon90!
Old Jul 9, 2008 | 05:34 PM
BigJoe's Avatar
BigJoe
Maybe the 2005s are different but when I park my car at work in the morning the thermometer says whatever the current temp is, say 80 degrees. When I get in it at night and start it up the thermometer instantly says 100 or whatever the now current temp is. I don't have to drive a foot. (Yeah it gets hot in TX...)
Old Jul 9, 2008 | 05:36 PM
c6run's Avatar
c6run
.....or all the other temp gauges are all wrong and the vette is the only right reading!
Old Jul 9, 2008 | 05:41 PM
StoplightWarrior
I had that thought, but it is DEFINITELY hotter than 84 today
carnut08's Avatar
carnut08
I learned that trick from an earlier post here on the Forum. It was probably Talon then too. Thanks, buddy!
Old Jul 9, 2008 | 05:44 PM
mforman42's Avatar
mforman42
If you're parked all day, it will display the current temp when you start.
Old Jul 9, 2008 | 05:58 PM
talon90's Avatar
talon90
NCM Ambassador
To damn...first problem with the c6 :(
