Fob
Old Jul 15, 2008 | 04:14 PM
robbie69's Avatar
robbie69
Cruising
Default Fob
My FOB is acting up. Car would not start with Fob in console. I picked in up and car started. Sometimes car will lock with FOB in console. Any Ideas? Thanks, Ron.
Old Jul 15, 2008 | 05:20 PM
Vette_DD's Avatar
Vette_DD
The antennas in the car that detect the fob are not detecting the fob when it's in the console. I don't know if they should or not, but I'd try to find a place on my person where I could keep the fob when I'm in the car.
Old Jul 15, 2008 | 05:23 PM
HawaiiC6's Avatar
HawaiiC6
The console may be to far for the fob to be detected I always keep my fob in my right front pants pocket, never leave it in the console just in case you get out and close and lock the door. By keeping the fob in my pocket I cannot be locked out.
If there are any questions on your fob then place it in the fob slot which is located in your glove compartment left side. If the car does not start and you get a reading fob not detected then your fob battery needs to be changed.
Old Jul 15, 2008 | 05:31 PM
bksnoopy's Avatar
bksnoopy
I guess I should ask you if you tried the other fob?
Next:
I would put a FRESH battery in the fob. Even if the battery is not that old .... start with a new battery.
If both fobs do the same thing I would still try a new battery. That might sound silly but it will eliminate the batteries.
Ben, OH
Old Jul 15, 2008 | 05:35 PM
WGO's Avatar
WGO
Never tried it with my FOB in the console. Too darn likely to leave it in the car. I always keep the FOB on my person so it leaves the car when I do, without having to think about it.
I usually wear jeans and it fits perfectly in that silly little pocket on the right side above the regular pocket.
Old Jul 15, 2008 | 07:35 PM
cclive's Avatar
cclive
I tested my fob and it will start the car if it is in the glovebox slot even without any battery in it. Also, from what I have heard here, the system for making sure that the fob doesn't get locked in the car is just not very dependable so probably not a good idea to rely on it.
Old Jul 16, 2008 | 03:42 AM
bolivar's Avatar
bolivar
Do you have any other electronics active in the car? Cell phone, cell phone charger, DC to AC converter?
Any/all of these have been known to interfer with the car being able to sense the Fob.
Old Jul 16, 2008 | 06:39 AM
Doing69's Avatar
Doing69
Does this happen with the other FOB? If not, I would change the FOB battery.
The location of the FOB inside the car does seem to be overly sensitive.
Please note: The default auto locking feature will lock the car doors if a FOB is left inside the car and the doors are closed.
Old Jul 16, 2008 | 05:53 PM
bksnoopy's Avatar
bksnoopy
You have a good point. I have a pole barn that I keep my motor home in and it has 3 garage doors with electric door openers on them. To make a long story short, every time I plug in the motor home and the converter is running, the garage door will not open with the remote control. I enter the barn through the side man door and open one of the garage doors with the corded wall switch. If I unplug the motor home, the doors will work with the remote.
Peace .. Ben, OH
To Fob
