fuel injector service
RK
Are you sure they didn't say "flush the injectors"? Frankly, not many dealers are dumb enough to sell fuel injectors as normal maintenance. Double check with them, if they do want to sell injectors, and the car runs fine, tell the service manager or higher.
I would either talk to the service manager, general manager, or owner. Or try another dealer if that's better for you.
You can run some Techron concentrate through the fuel system. It can be purchased at any auto parts store.
Run, do not walk away from this money, grubbing, lying, chiseling dealer. They are working on transferring money from your account to theirs by spreading misinformation (we called it lying where I grew up).
I would not patronize this dealer for the simple fact that they are not trustworthy. If they lie to try to get you to spend money needlessly, why would they be dissuaded from not doing service that they charge you for???
Pure thievery. Plan and simple.
Better that you should share the name of this dealer - the stupid shall be punished - this dealer should loose money by being advertised as a criminal.
Required services are described in the following for
“Maintenance I” and “Maintenance II.” Generally,
it is recommended that your first service be
Maintenance I, your second service be Maintenance II,
and that you alternate Maintenance I and Maintenance II
thereafter. However, in some cases, Maintenance II
may be required more often.
Maintenance I — Use Maintenance I if the message
comes on within 10 months since the vehicle was
purchased or Maintenance II was performed.
Maintenance II — Use Maintenance II if the previous
service performed was Maintenance I. Always use
Maintenance II whenever the message comes on
10 months or more since the last service or if the
message has not come on at all for one year.
Aside from oil changes that are determined by the DIC, these are the items that need attention at the mileage indicated:
