Exhaust Install Question
Old Jul 17, 2008 | 02:38 PM
geezer04's Avatar
geezer04
Default Exhaust Install Question
Finely got a lift installed in my garage, so can now install a new exhaust.
Will be installing a Corsa Touring. Any trick or problem that I should be aware of, or is it straight forward?
Old Jul 17, 2008 | 03:09 PM
Rogers 07's Avatar
Rogers 07
A good work practise is to install the entire system with all the bolts and clamps installed just enough to hold evrything together, make final fit up/ alignment adjustments etc, then tighten all clamps and bolts accordingly,You should have no issues as long as you follow the MFG instructions
Old Jul 17, 2008 | 03:15 PM
WAwatchnut's Avatar
WAwatchnut
Double check the over axle pipes to make sure there's enough clearance all around the pipes. Since I installed my Powerflo about 1 month ago, I've already heard first hand from 3 other forum owners about noises when making turns... all traced back to the pipes bumping the underbody. The exhaust is only hard mounted at the front of the H pipe - everything else is free to move around (by design), so clearance is very important.
Old Jul 17, 2008 | 04:37 PM
SvetteC6's Avatar
SvetteC6
I installed mine a few weeks ago on my race ramps. Straight forward, I loosely tightened everything, checked alignment and then final torqued. the only problem was torqueing the upper studs on the front flanges. I couldn't get the torque wrench up there so I had to guess.
I love the exhaust, enjoy.
Old Jul 17, 2008 | 04:49 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Take your time, follow the instructions and make sure everything is aligned before tightening things up.
BE CAREFUL with the bolts attaching the new H-pipe to the flanges behind the cats. All the instructions say is "tighten to factory specs." I don't recall the exact specs but it's not NEARLY as high ans the other bolts/nuts. Check that torque spec before doing the work or you're likely to do damage.
Otherwise it's pretty straightforward.
Good luck and have fun!
Old Jul 17, 2008 | 06:02 PM
geezer04's Avatar
geezer04
Thanks for the response. Time to go mash my knuckles
Old Jul 18, 2008 | 04:24 PM
drbonebreak's Avatar
drbonebreak
Drain holes point DOWN. Like anybody could mess that one up the first time...
To Exhaust Install Question
