Pine tar
Old Jul 18, 2008 | 08:44 PM
C746490's Avatar
C746490
Default Pine tar
Any good ways to remove pine tar and or tree sap from vert top and clearcoat?
I have two coats of Rejex on the clearcoat and Ragg top protectant on the soft top.
I am going on a trip and I want to plan on the what if's - any good advice is greatly appreciated.
Old Jul 18, 2008 | 09:03 PM
mksz51's Avatar
mksz51
Washing (especially with warm water) should remove it just fine.
Old Jul 18, 2008 | 09:06 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I always like the advice that is "less", meaning, the less abrasive, chemical, or "abusive", the better. I'd say bring some claybar and detailer with you for the painted surfaces. Maybe even a very small bottle of rejex, like a travel bottle that's well-sealed so it doesn't leak.
For the top? that's a toughie. Why not call Ragg before you leave and ask them? Tell us what they say.
Before I had the Ragg on my Top, someone decided my car, overnight needed a coating of coke or some such on it. Fortunately, I caught it just after the sun came up, and after a long discussion with the hotel owner, got to use their hose and water to flush it all off. If it had sat on there all thru the hot sun, I am certain it would've stained badly.
Good luck.
Old Jul 18, 2008 | 09:35 PM
Americas Team's Avatar
Americas Team
Believe me, on the clear coat straight kerosene will work great. On the top, I have not a clue.... Good luck!
Old Jul 18, 2008 | 09:40 PM
carboman's Avatar
carboman
Goof off works great. The wipes are handy to keep in the car. Removes tar, sap, bugs, etc.
http://www.idealtruevalue.com/servlet/the-49788/Detail
Old Jul 18, 2008 | 09:57 PM
cclive's Avatar
cclive
I would expect that any good car soap like Meguiars etc would do just fine, soft brush and air dry. I have to park under a tree when I go visit my sister and am planning on putting a sheet over the vert top when I am there.
Old Jul 19, 2008 | 01:33 AM
Jimbeaux's Avatar
Jimbeaux
Wd40
Old Jul 19, 2008 | 02:13 AM
Body Teacher's Avatar
Body Teacher
Rubbing alcohol is the best for sap and evaporates very quickly so it won't bite into the finish.
Old Jul 19, 2008 | 02:16 AM
4thC4at60's Avatar
4thC4at60
Old Jul 19, 2008 | 08:45 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Just tried it on some long leaf pine sap (Southern Yellow Pine) and it works. Soap and water does nothing.
Old Jul 19, 2008 | 08:52 AM
Mad*Max's Avatar
Mad*Max
Can't help with the top but I have personally removed from the paint with Nu Finish - might have to do it twice.
Old Jul 19, 2008 | 09:45 AM
nmerhaut's Avatar
nmerhaut
old school like me and works every time.
Old Jul 19, 2008 | 10:16 AM
C6LSx's Avatar
C6LSx
St. Jude Donor '08
Off topic.....with regard to "pine tar"; anyone remember George Brett's mental meltdown when his homerun was taken off the scoreboard by the homeplate umpire for too much pine tar on his bat?
That bat (with pine tar) now resides in Cooperstown.
Old Jul 20, 2008 | 07:00 PM
Jedsvet's Avatar
Jedsvet
I just took some large pine tree sap drops off with denatured alcohol, it did not seem to cause any problems.
I have a lot of small specks as was considering wiping down the entire car. After this I would give it a nice coat of wax.
any problems with this idea?
Old Jul 20, 2008 | 07:35 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Alcohol works. Actually, a number of things work. Today's OEM paints are very tough.
My favorite is paint thinner or mineral spirits. Kerosene also works as does WD40. Start with these first. Lacquer thinner works, too, but make sure you use it one factory or fully on cured OEM paint.
Never use: MEK or acetone.
Or Scotch Bright. I had a friend remove tree sap with a Scotch Bright. I had to buff the scratches out.
Old Jul 20, 2008 | 08:37 PM
sranger's Avatar
sranger
I actually prefer Denatured Alcohol since rubbing Alcohol is about 80% water. ( You can get it at any home store ) It is a little stronger and will remove the grime with less rubbing that can mar the finnish...
However, keep in mind the either will completely remove any wax from the finnish. It is a good idea to wax the area after cleaning...
Old Jul 20, 2008 | 10:04 PM
firemon's Avatar
firemon
whatever you try it will work much better if the pitch is warm maby a hair dryer will help you get results
Old Jul 20, 2008 | 10:27 PM
Tommyleon's Avatar
Tommyleon
Default Pine Tar removal
My wifes aunt has a house in Destin Fl. with NO garage.She parks under pine trees and when I visit ,my job is to remove the pine tar!I've tried everything........trust me alcohol disolves it very quickly.
To Pine tar
