getting really hot and bothered here...
Old Jul 21, 2008 | 08:57 PM
branmin's Avatar
branmin
Default getting really hot and bothered here...
Been driving poor Corvettemods1 mad tonight..back and forwards PM's.
Trying to put some of his LED lights in my footwells. First, I just cannot get the orginal foorwell lights to go off. It states in the manual that by pressing the instrument panel brightness ***, one can turn them on and off. Yes it works with the door closed, but not open and there is no way I can reach under the dash with the door closed. Didn't seem right to change them whilst they were on??
As if that wasn't bad enough....obviously I am just not paying attention to what one is supposed to do but one is meant to get a small screwdriver and lightly jimmy it somewhere...........well I presumed it was where the lens cover is to release this cover, but can't do this either?? HELP...................... am now having a large Vodka..
Old Jul 21, 2008 | 09:49 PM
branmin's Avatar
branmin
anyone?
Old Jul 21, 2008 | 09:51 PM
CQRT's Avatar
CQRT
can you tape the plunger switch closed on the door jamb so the car thinks the door's closed ?
Old Jul 21, 2008 | 09:56 PM
moolys's Avatar
moolys
St. Jude Donor '09
Or take out the fuse
Old Jul 21, 2008 | 10:03 PM
branmin's Avatar
branmin
Probably the best way to go..however, why isn't the brightness *** doing what it's supposed to do.?......................could someone try this on your car and see if it turns off with the doors open. then I will know it's not just a fault on my car...they all happen like this, but if so, would like to know how people are changing their bulbs..with the lights on..surely not? Thx.
Old Jul 21, 2008 | 10:12 PM
DaddyRay's Avatar
DaddyRay
Maybe I'm a dummy, but I just installed mine a few minutes ago, all eleven, and did them all witht the lights on. So I could tell if they were in backwards or not Polarity issue, ya know. Mine work fine...
DaddyRay's Avatar
DaddyRay
Oh...and they won't turn off with the doors open...Just pop out the whole fixture....
Old Jul 21, 2008 | 10:17 PM
branmin's Avatar
branmin
No your'e no Dummy...I'm the Dummy............Ok will try with the lights on..............maybe the footwells don't go out with the door open anyway(just asking)........................would you mind giving some detail into where you put all the lights(besides the license plate) and in particular, how you got the footwell light cover off? Any any tips on the maplights..thx. just not my day
Old Jul 21, 2008 | 10:26 PM
firemon's Avatar
firemon
Map lights are a pita finally got mine out by using a very small flathead screwdriver on one side and my finger on the other side of the bulb and gently pulled and rocked back and forth simutainousley might also try to slip some vacume tubing over the bulb so you have something to grip
Old Jul 21, 2008 | 10:27 PM
DaddyRay's Avatar
DaddyRay
The map lights I popped off with a pocket knife....Yea I was nervous too.....they'll pop out in the floor with a lil' pressure..gently.....the under dash lights, just pop out the whole damn thing, not just the cover....change the bulb and stick 'em back in....
oh, and DON'T break a map light bulb.....I understand that will make for a bad day.....
Glove Box..1 bulb...(REAL PITA)
Marker lights...4 bulbs
Map lights....2 bulbs
Under Dash...2 bulbs
Lic Plate.....2bulbs
Old Jul 21, 2008 | 10:32 PM
branmin's Avatar
branmin
You say........."just pop out the whole damn thing, not just the cover"
Are you referring to the large plastic cover under the dash....? by pulling this whole unit out??
Thx for your help.............
Old Jul 21, 2008 | 10:34 PM
DaddyRay's Avatar
DaddyRay
Yup....the square light fixture..not the whole plastic cover, just the light...
Old Jul 21, 2008 | 10:37 PM
branmin's Avatar
branmin
got ya...over and out........... phew!!!!!!!
Old Jul 21, 2008 | 10:41 PM
RRVettes's Avatar
RRVettes
Gotta love this place when you need help!
Old Jul 21, 2008 | 10:45 PM
danl72's Avatar
danl72
mpuzach's Avatar
mpuzach
I've NEVER heard of under-dash lights (in any vehicle) that can be turned off with either door open.
Old Jul 21, 2008 | 10:46 PM
DaddyRay's Avatar
DaddyRay
To getting really hot and bothered here...
Old Jul 21, 2008 | 10:48 PM
MarkRx's Avatar
MarkRx
are all these LED's 194's with the exception of the map light? or just give us a parts listof the bulb numbers.. ex: 168, 194, 1157, 3027, 3157 etc etc.
Old Jul 21, 2008 | 10:49 PM
branmin's Avatar
branmin
But since many here say..."Read Your manual" I did and look what it says under Courtesy Lamps on P. 3-18
Old Jul 21, 2008 | 10:58 PM
BAD Z06's Avatar
BAD Z06
just posted a pic in this thread with help for taking it out hot
http://forums.corvetteforum.com/show...post1566399729
