Whats True Horsepower of LS3?
Old 07-25-2008, 03:51 PM
slojoh
slojoh's Avatar
Originally Posted by BetterMostC6
Its the dual mode exhaust "NPP" thats rated at 436hp. The suspension option Z51 has nothing to do with HP unless it also has the NPP option. NPP can also be ordered without Z51.
slojoh is offline
Old 07-25-2008, 04:04 PM
0Brian@RPT
Former Vendor
Brian@RPT's Avatar
I read awhile back the LS2 would have been 395hp under the SAE Cert. The days of the underating are gone if the engine is certified. Kinda like the F-Body LS1 rated at 305hp and some dyno'd that.
Brian@RPT is offline
Old 07-25-2008, 04:33 PM
Fuego
Fuego's Avatar
I've seen the same thing. According to the old rating system, the LS3 would be in excess of 440+hp.
Fuego is offline
Old 07-25-2008, 08:13 PM
JJC5
JJC5's Avatar
Originally Posted by talon90
Michael,
Two part answer. Part one:
MN6 15%
A6 18%
In terms of what folks like to use for calculating RWHP from BHP.
Part Two:
(I've posted this previously)
I don't believe that a "15%" assumption is correct for the LS3. I believe that the LS3 is closer to 10 or 11% (if expressed in percentages, which I don't believe in that either). It appears that the LS3 drivetrain is loosing between 40 and 45 hp to the wheels.
The problem always comes down to the tolerances and differences vehicle to vehicle. There is no way to accurately predict crank horse power from rear wheel horse power. The only legitimate means of approximating driveline loss is if you have a baseline number for the crank on that vehicle and then can get an accurate rear wheel measurement on a dyno.
Driveline loss should not change on a given vehicle once established. What I mean by that is the same components should keep the same loss (allowing for wear) over the entire horsepower curve as modifications are made. If you use a divisor such as .85 (15% loss) you are taking more from the drivetrain as horsepower increases and that just shouldn't happen. For example:
baseline
400-60 (15%) = 340 on a stock C6 manual.
add intake and exhaust (gross about 15hp)
415-60 = 355 as the driveline didn't change so all the same friction and slop is present.
but using the conventional 15% it would show:
415-62.25(15%)= 352.75
Not too significant at lower hp ratings but think about as you begin to add a supercharger (150hp)
550-82.5 (15%)= 467.5 Why would the very same driveline now all of a sudden create a 82.5hp loss? No increased friction, so it should not.
The percentage of driveline loss SHOULD change with horsepower. If it didn't, the higher the HP, the more loss there would be. The percentage should DECREASE with more HP. Driveline loss is a relatively consistent number or "baseline". The LS3 SHOULD and does show 30 to 36 more than the LS2.
JJC5 is offline
Old 07-25-2008, 09:24 PM
RRVettes
Support Corvetteforum!
RRVettes's Avatar
Originally Posted by jschindler
What if it has a badge?
Badges add weight and drag, so they have an undesirable effect. That is why everyone takes off the GM chicklets, to decrease weight and drag..they just say they don't like the look, while secretly they hope to have a competitive advantage over Vettes with the chicklets.
RRVettes is offline
Old 07-25-2008, 11:06 PM
NyCorvette2017
NyCorvette2017's Avatar
Default LS3 with NPP HP?????????????
A couple of weeks ago someone with a manual 08 LS3 with NPP dynod there car and it showed roughly 450HP without any modifications. Who knows, the LS3 is superior to the LS2 in many ways, and is the engine less some mods used in the ZR1. As far as whether the LS3 with NPP has 436 or 450hp, the car is crazy fast. You never use the power, and the margin of difference is just for those who crave HP numbers.
NyCorvette2017 is offline
Old 07-26-2008, 07:53 AM
jschindler
jschindler's Avatar
HUH? Do you mean that the actual "Corrected" rwhp was 450, or is that what they translated to be the crank HP? No way would a bone stock LS3 actually dyno at the wheels at anywhere even remotely close to 450.
If they were trying to translate it to crank hp, go back and read this whole thread again - they likey used the old rule of thumb that is not valid.
jschindler is offline
Old 07-26-2008, 09:24 AM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I'm afraid that this might be one of the type of threads he is referring to.
http://forums.corvetteforum.com/show...ighlight=Horse
In this case it was a matter of the OP using the percentage method to arrive at a back calculated number that I'm afraid was just a bit on the optimistic side.
talon90 is offline
Old 07-26-2008, 09:40 AM
IRS-Cop
IRS-Cop's Avatar
Originally Posted by biskitman
I have an 08' Coupe with LS3 and NPP, supposed to be 436 hp. I have seen others say its 10-15 more actually and some says its 10-15 less. I know that a dyno would tell me but they are subjective also and I dont want to go to the expense, wear, etc. My car is bone stock MN6 Is the 436 advertised pretty accurate? I know the gear heads will chime in with accurate answers.
I can tell you that our 436 SAE certified Horsepower is way more than any L71 427 (435 HP) or even the L88 427 (430 HP) ever made.
What I would like to know is what our engines would be rated at in Gross HP.....it would have to be close to 550HP I'm sure....lol.
IRS-Cop is offline
Old 07-26-2008, 09:52 AM
besz28
besz28's Avatar
I hate to disappoint the others but the LS3 is not underrated. The car's horsepower is certified to an SAE standard which have very little tolerance for underrating and overrating. As such, it is what it is. The reason that everyone things they have more power is that they are applying outdated "guesstimates" for drive line loss and attempting to back calculate flywheel horse power from rear wheel dyno results. The former assumptions on loss don't work with the LS3 and T6060 as the transmission and drive line is a more efficient package. If you apply the old routine you end up with some outlandish claims of crank horsepower.
you must have an ls2
besz28 is offline
Old 07-26-2008, 10:30 AM
talon90
talon90's Avatar
NCM Ambassador
As a matter of fact I do. What exactly would that have to do with information I posted? Surely you are not believing that my post would have somehow been different if I had an LS3 are you?
talon90 is offline
Old 07-26-2008, 10:54 AM
catpat8000
catpat8000's Avatar
I think one of the reasons this keeps coming up is this apparent contradiction:
The LS2 engine is rated 400hp and many LS2 cars dyno around 340-350 rwhp for a 13% driveline loss.
The LS3 engine is rated 430hp and many cars seem to dyno around 390, for a 9% driveline loss.
Now I used these numbers because I used to own a 2005 LS2 and I currently own a 2008 LS3. I had both cars dynoed when bone stock and these were the numbers I saw.
LS2 - 345 rwhp
LS3 - 390 rwhp
My LS3 appears to dyno approx 45 ponies more than my LS2 at the rear wheels, after the driveline loss. But wait a sec! That's more than the flywheel hp rating difference between the engines! How could that be?
Some say perhaps the LS3 is under-rated but in fact, as you point out, Chevrolet is voluntarily using a new SAE certification for the LS3 engine which requires every engine shipped will deliver within 1% of its advertized rating. So it is unlikely for Chevy to be sandbagging on the engine.
There are two theories floating on the web, both of which probably have some truth:
1. The 2008 vette has a new clutch, new transmission, and significantly altered differential. Perhaps the driveline losses are reduced in 2008.
2. The 2005-2007 LS2 engines were not rated using this new SAE certification. Perhaps Chevy was exaggerating their output.
At any rate, I have seen this contradiction first hand with my cars.
Pat
catpat8000 is offline
Old 07-26-2008, 11:22 AM
  #33
joytown
joytown's Avatar
Hey - I resemble that remark!
Yeah .. my stock LS3 w/NPP pulled 380HP at the wheels. Based on the 15% drivetrain loss (A6) "rule of thumb", my car would be turning 475 at the crank. As was pointed out in my LS2 vs. LS3 - this is just a tad bit unrealistic.
I bid you to search for that thread - Talon's layout of the calculation was very informative. I love when I learn new stuff.
Bottom line - the 436 is a pretty close number, and while it certainly may be off, it's not off by much.
-jon
joytown is offline
Old 07-26-2008, 11:24 AM
  #34
not08crmanymore
not08crmanymore's Avatar
If it's 90 degrees and MUGGY out you have less HP.
If it's 40 degrees out,you have more...or at least it will feel that way and perception is 90% of the game!!
not08crmanymore is offline
Old 07-26-2008, 11:26 AM
  #35
joytown
joytown's Avatar
Originally Posted by HarleyB
That is ALWAYS good for 12 - 15 HP!!!
Don't forget the optional 1 HP mod as seen here:
-jon
joytown is offline
Carvin (01-17-2017)
Old 07-26-2008, 11:35 AM
  #36
JJC5
JJC5's Avatar
You loose 40 to 50 HP through the drive line period. If you had a 1000 HP up front, you'd have about 950 RWHP. If you use the 15% method, you'd loose 150 HP through the same driveline. The LS3 has 30 HP more than the LS2.
JJC5 is offline
Old 07-26-2008, 12:36 PM
  #37
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
with many of the post above with regard to the Certified horsepower rating of 436hp.
Just a few things to add having been in correspondence with SAE about this very subject, but with regard to the LS7. The same would apply to the LS3 or any SAE Certified horsepower rated engine.
http://forums.corvetteforum.com/show....php?t=1940271
This number is arrived at under specific testing conditions.
Under the controlled repeatable conditions as outlined in SAE J2723, production engines intended for installation into vehicles for sale to the public produce the SAE J1349 Certified Horsepower figure plus or minus 2%.
When the actual testing is done, on the engine dyno, so that the manufacturer can assign a horsepower rating, it is done with an SAE witness present, in part to insure that the testing is done in compliance with SAE document J2723.
The manufacturer is allowed to claim a number which is within 1% up or down of what the SAE witness observes during the testing.
Again, the engines tested have to be intended for use in production vehicles, have to run fuel consistent with that recommended by the manufacturer, and have to run the same calibrations and be emissions compliant, (ie have cats) during the testing.
Underrated. Amazing how many people want that to be true and it simply isn't.
LS3, LS7 and LS9 or any other SAE Certified rated engine, is not "underrated".
I have often wondered, what would be GM's motive for "underrating" any of these engines??
Results taken from off a chassis Dyno in the typical tuner shop can vary widely.
Interesting tidbits, the 638 hp SAE Certified LS9 going into the the ZR1 is the 100th engine to receive SAE J1349 certification. The LS7 found in the C6 Z06 was the first GM engine to be Certified under this new standard.
Thus with the SAE J1349 rating system, the manufacturer is saying that under the same controlled conditions, all LS3 engines intended for use into the C6 Corvette, make to within 2% of 436hp plus or minus.
You need not worry that your LS3 is making appreciably less power than your buddy's LS3.
'06 Quicksilver Z06 is offline
To Whats True Horsepower of LS3?
Old 07-26-2008, 12:51 PM
  #38
HarleyB
HarleyB's Avatar
436 HP is fine with me.
HarleyB is offline
Old 07-26-2008, 02:25 PM
  #39
GotVett?
GotVett?'s Avatar
Whew!! Ok, the LS3 is the newest out with a few additional hp and slight improvements. No argument there. Some tend to get onto those who think the LS2 is more than it is, so by the same token, don't think the LS3 is more than it is. In real life, on the street, no big difference at all. More "bragging rights" of having the latest year is all. Now, get a Z or equivelent and now your talkin!!
GotVett? is offline
Old 07-26-2008, 02:40 PM
  #40
ZPirate
ZPirate's Avatar
Good points Phil. The LS3 is part of the evolution of the C6 along with the other improvements that began on the 08.
ZPirate is offline
Quick Reply: Whats True Horsepower of LS3?
