strange noise
Old Jul 27, 2008 | 12:06 PM
SHen350's Avatar
SHen350
Default strange noise
Last night while driving my new 08 C6 I was heard a strange sound that I haven't heard before. It sorta sounds like a card in a kids bycycle spokes. It's rather faint and can only be heard when I am moving. I have an LS3 MN6. If I am sitting at a stop light with or with out the clutch in I can't hear it. If the clutch is in it also doesn't make the noise. It is only when I have the car under power that I can hear it. It's no louder with the windows down as with them up and if the air is on more then low it drowns it out.
I have no idea if this is a normal sound or not. I don't recall hearing it before, but I only have 150 miles on the car. Just wondering if this is a normal sound or something I should have looked at, thanks.
Old Jul 27, 2008 | 01:09 PM
b4i4getit's Avatar
b4i4getit
Should be easy to find. If it only happens when the car is in motion then it has to be related to some rotational issue. Check each wheel well and under the car for some stray piece that is flapping in the wind. It could be a sticker or something like that.
Old Jul 27, 2008 | 02:55 PM
fleetc's Avatar
fleetc
Check for a cat under the hood.
By your description, definitley something to do with wheels or driveshaft.
Old Jul 27, 2008 | 02:59 PM
hulksdaddy's Avatar
hulksdaddy
If you hear it mostly in the 1500-2200 rpm range, it's the normal "ticking" sound all LSx engines make.
Between the injectors and valvetrain, these motors make some noise. Both my LS2 and LS7 have made it.
Perfectly normal.
Old Jul 27, 2008 | 05:24 PM
HawaiiC6's Avatar
HawaiiC6
Is the sound at all speeds? In slow turns?
Old Jul 27, 2008 | 06:37 PM
RussellZ's Avatar
RussellZ
Remove the baseball card from your spokes and the noise will stop.
Old Jul 27, 2008 | 09:52 PM
SHen350's Avatar
SHen350
It's all the time at all speeds when the trans is engaged. It is a little louder in 4th gear then the others, but always there.
Old Jul 27, 2008 | 10:26 PM
dpigguy's Avatar
dpigguy
I have the same set up but no noise - engine does make a ticking sound around 2000 rpms which may be what you are hearing if that is the range of engine speed you are at. otherwise, sounds like you may have a dealer visit in your future
Old Jul 27, 2008 | 10:43 PM
cclive's Avatar
cclive
Does it go faster as the car speed increases, or faster as engine RPM increases, or same at all speeds and RPM?
Old Jul 28, 2008 | 10:13 AM
SHen350's Avatar
SHen350
No, it doesn't really go faster I don't think, or get louder other then in 4th gear. I am going to drive it a little today and check RPM's.
Old Jul 28, 2008 | 10:24 AM
biskitman's Avatar
biskitman
Could be an exhaust leak.
To strange noise
