Tire Pressure question
Old Jul 31, 2008 | 07:28 AM
kakariki's Avatar
kakariki
Default Tire Pressure question
My new c 6 says reset tire pressure monitor on the DIC
I push the Reset button- says reset accepted.
Do I need a diagnostic tool ?? To make it ??
I can not see tire pressure on my DIC
And reset tire pressure comes again
Old Jul 31, 2008 | 08:08 AM
dpigguy's Avatar
dpigguy
assume you will need to have the sensors reset from the write up. dealer can do or you can purchase tool and do it yourself. unless you are going to be changing tires a lot (i.e. tracking car), I would just let dealer reset.
Old Jul 31, 2008 | 09:16 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The sensors need to be registered. Take it to the dealer or most good tire shops.
Old Jul 31, 2008 | 10:27 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The reset that you are performing will clear the error message for that ignition cycle. It sounds like you have a defective or unregistered TPS. Is this a new sensor? Did you have wheel work done? Did you have new tires put on the car? How old is the car? Are you the first owner? Need more information.
The only way to register the TPS to the car is using a tire pressure monitor reset tool. Most dealerships and tire outlets will have one that will work with your car. The car needs to be put into learn mode and all four TPS will have to be reset to log the sensor id with the car.
Old Aug 1, 2008 | 03:45 PM
kakariki's Avatar
kakariki
Its a new car, but maybe the battery has been disconnected, when it was modified for use in Sweden
Old Aug 1, 2008 | 05:45 PM
2009 C6's Avatar
2009 C6
To Tire Pressure question
