I know its a new exhaust for 08 but what is all this talk about mild to wild switches and so fourth? Is the exhaust not the same sound all the time? Is it only loud at WOT? Im confused
The exhaust opens up at 3500 rpm to make a louder sound. It stays open as long as the rpms are above that point. The Mild to Wild setups let you determine when it will be open and when it won't.
I'm sure the primary reason the flaps are closed until around 3000 rpm is to meet an EPA gas mileage target.
I think noise is the primary reason. With the flaps open, it's fairly loud, and pretty boomy inside the car. The sound is fun to play with around town, but the drone would annoy the heck out of me (and many others, I'm sure) on the highway.
To my knowledge, there is no difference in EPA ratings between NPP and non-NPP cars.
The NPP is the RPO (regular production option) code for the bi-mode exhaust that is available on the coupe and convertible. This exhaust is modelled after the exhaust on the Z06. The exhaust uses a butterfly valve over one of the exhaust exit pipes (two total, one per muffler) to vary the exhaust output. It works similar to exhaust cut-outs popular on the street rods.
The exhaust control is operated by engine vacuum pressure. The system is tied to the pcm and monitors rpm and throttle position to measure "driver intent".
Under normal circumstances the exhaust valve is closed and it routes the exhaust gas out of the other pipe after it passes through the baffle chamber of the exhaust. In this case it is quieter. If the driver accelerates hard the valves will open at 2,800 rpm as long as the driver is above 80% throttle. Between 30% and 80% throttle the exhaust will open during acceleration at 3,500 rpm.
Here is a diagram of the routing of the exhaust gas and operation of the muffler system.
Here is a graph of the opening and operating characteristics of the exhaust.
One correction. When you have a Mild2Wild switch you can open the valves whenever you want but when it is closed it acts as stock. There is no way to keep the valves closed over 3500 RPM.
Paul
does the "closing line" indicate that the baffles stay open until a much lower TPS reading is observed then when they open? I have noticed that you can overcome some of the "burble" by maintaining a slight pressure on the throttle but this chart would say that is not true. just curious
