is this normal
Old Aug 5, 2008 | 08:37 PM
aquavettes's Avatar
aquavettes
Default is this normal
There are what look like sparkles in the headlight lenses. Hope you can see them in these pics. Does anyone else have them or is this a warranty issue?
the car is an 07, 16 months old and 10k miles
sparkles are inside the lens..
Old Aug 5, 2008 | 08:55 PM
nmerhaut's Avatar
nmerhaut
Looks like sandblasting from road debris. Had stuff like that before invisible bra and headlight protectors were applied. Might buff out with the Mother's power ball and plastic polish.
Old Aug 5, 2008 | 08:57 PM
Vet's Avatar
Vet
Yeah, looks like normal wear and tear. Nothing to worry about. Just drive it.
Old Aug 5, 2008 | 08:58 PM
danl72's Avatar
danl72
See if you can clean it off.
Old Aug 5, 2008 | 08:59 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
if it is on the outside, mothers makes a product to restore clear plastic lenses....worth a try
Old Aug 5, 2008 | 09:06 PM
95blklsc's Avatar
95blklsc
use xpel headlight protectors, they work great!
Old Aug 5, 2008 | 09:09 PM
Zotic's Avatar
Zotic
If undetectable by touch, then something inside, otherwise road mementos.
Old Aug 5, 2008 | 09:10 PM
Rocketmanwpb's Avatar
Rocketmanwpb
You can buff it out. Start with a cleaner wax and if that does not get it then you might try mild rubbing compound and a buffer. Need to be careful and not hit the paint. If you use the buffer tape the surrounding paint to protect it.
Old Aug 5, 2008 | 09:34 PM
cclive's Avatar
cclive
Can't tell from the pic, are they on the inside or the outside. If they are outside, then you should be able to feel them with a fingernail. If inside, then I would say warranty.
The outside surface of the clear headlight cover is a thin layer of harder material to resist (not eliminate) chipping from debris. If you try doing heavy polishing to remove dings, you will remove this coating making the cover more suceptible in the future.
Old Aug 5, 2008 | 11:51 PM
moolys's Avatar
moolys
St. Jude Donor '09
To is this normal
