Oil Change Question
Old Aug 6, 2008 | 04:46 PM
Manny350Z's Avatar
Manny350Z
Default Oil Change Question
Hello,
Bought a 2007 C6 a few days ago want to get an oil change.
How much does this cost at a dealership?
Also can i go to a private shop that just does oil changes?
Like Mr Lube,Jiffy lube etc?
Old Aug 6, 2008 | 04:54 PM
RED2008Z06's Avatar
RED2008Z06
The dealer price will vary, Jiffy lube never, you would be better off doing it yourself...good luck
Old Aug 6, 2008 | 04:55 PM
User 020720's Avatar
User 020720
$70 at my local Chevy dealer. But you can save money by just doing it yourself.
Either way it'll take 5.5 qt or 6.0 qt (Z51) of Mobil 1 5W-30 and a PF-48 Delco filter and you're good to go.
Old Aug 6, 2008 | 04:59 PM
BlownV6's Avatar
BlownV6
Do not waste money on Mobil 1. Goto your local parts store and get Redline, Royal purple, German castrol or order Amsoil.
Then goto Walmart and have them change it. They charge 9 dollars to put in customer supplied oil and filter. It'll run you 54 dollars using RP and having it changed at Walmart.
Old Aug 6, 2008 | 05:10 PM
ATC399's Avatar
ATC399
verify oil filter PF48 LS3 Y/N
Old Aug 6, 2008 | 05:14 PM
Moltenice®'s Avatar
Moltenice®
I agree. ALL of my vehicles use Amsoil, I pay about the same or less for top of the line oil, compared to other people who pay to have it done at a shop.
I take pride in knowing the fluids going in are top notch, and the service is done with full attention to detail.
EDIT:
You could order from here if you dont have it local...
OIL
http://www.amsoil.com/storefront/asl.aspx
Filter
http://www.amsoil.com/catalog.aspx?code=EAO47-EA
"Guaranteed for 25,000 miles or one year when used in conjunction with AMSOIL motor oil in normal service"
^^ Goes to show how serious they are....
Old Aug 6, 2008 | 05:18 PM
BlownV6's Avatar
BlownV6
You really can't go wrong with a Group 4 oil that i listed above. Stay as far away from Mobil 1 as you can.
Old Aug 6, 2008 | 05:34 PM
Gordon Shumway's Avatar
Gordon Shumway
Whatever you do, don't use what is recommended by GM and printed on the oil fill cap.
Old Aug 6, 2008 | 05:38 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
do it yourself. Very easy. Save money and get the satisfaction of working on your vette.
Old Aug 6, 2008 | 05:40 PM
BlownV6's Avatar
BlownV6
M1 used to be a great oil till they cheapened the formula and now it's way too thin.
Old Aug 6, 2008 | 05:42 PM
jabez's Avatar
jabez
Originally Posted by Manny350Z
Hello,
Do it your self if you can. If you have to go to a place like Jiffy Lube I think they charge something like 65 bucks.
Old Aug 6, 2008 | 05:44 PM
rjwoerheide's Avatar
rjwoerheide
This is the only forum on which I've ever read people writing negatively about Mobil 1. I've used it in all my vehicles for years with great results. Yet, no one here seems to have any concrete facts about Mobil 1 being a bad oil.
Why not change the oil yourself?
Walmart changing my oil?! Not on your LIFE!
Old Aug 6, 2008 | 05:47 PM
User 020720
I stated the Delco PF48 since he has an 07 LS2. The filter changed in 07 for the C6.
But yes I believe the PF48 is also for the LS3 in addition to LS7 and 07 LS2's.
Old Aug 6, 2008 | 05:51 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Call me whatever you want to call me...but I'd recommend going with the GM recommended oil (Mobil 1 5W-30).
Changing it yourself is definitely the way to go. If you take it somewhere to have it done, make sure they know Corvettes and watch them like a hawk. There's nothing difficult about doing the oil change but it amazing how many posts there have been here about cars being overfilled or being damaged (i.e. cracked rocker panels) by clueless or careless mechanics.
Old Aug 6, 2008 | 05:55 PM
Vette_DD's Avatar
Vette_DD
Another data point for the price of the dealer changing the oil & filter - $65 at my dealer's.
Old Aug 6, 2008 | 06:00 PM
Kent1999's Avatar
Kent1999
To each their own I guess....
If you like the other oils better, that's cool -- there's lots of good oils out there besides Mobil1.
However, if you have some _hard evidence_ that M1 is bad oil, we'd all love to see it.
Mobil1 has been flawless for me for the last 15 years or so, and I haven't seen anything that would convince me to switch from the OEM recommended fill.
Cheers,
Kent
Old Aug 6, 2008 | 06:01 PM
BlownV6's Avatar
BlownV6
The walmart monkeys aren't THAT bad. Just watch them drive it in and pour it in.. Done.
As for M1.. Go to LS1tech or bobistheoilguy.com and do some reading about the quality of M1 vs Amsoil, RP, German castrol and redline. It's Garbage
EDIT - I'll post up somethings after work tonight. Here are some video's/article's i've found on the web.
"It is hard to believe that oil alone can generate power and had we not performed the testing ourselves we wouldn't believe it either. By swapping out the factory oil with five quarts of Royal Purple 5W-30 weight synthetic oil the Mitsubishi peak power increased to 300.9 horsepower, a stunning increase of 7.2 horsepower. Looking at the dyno curve you can see that the engine was able to generate more power throughout the powerband from beginning to the end. The Royal Purple oil reduced friction allowing the engine to produce more power."
Bearing test
http://www.youtube.com/watch?v=kqvhRi7-iMA
To Oil Change Question
Old Aug 6, 2008 | 06:05 PM
maxp's Avatar
maxp
Cheers,
Kent
$75 at my dealer
Old Aug 6, 2008 | 06:28 PM
VET4LES's Avatar
VET4LES
Do it myself for $35. Mobil 1 and Delco filter. Takes 20 minuets and I know it's done right.
Old Aug 6, 2008 | 07:15 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
But I haven't mastered doing the 20 minuets while changing it yet!
