I just installed a set of replacement tires on my 05 Coupe. The OE Supercar's were "done" at 14K miles. I replaced them with GY's F1 GS-2 and I enjoy the difference in the ride, much smoother and significantly quieter.
I checked the tire pressure the following morning, after the install and it was 30lbs all the way around. The TPMS readout on the way home after the install was 30lbs as well.
This morning, two days later, the TPMS read 27lbs front and rear. The tire gauges I have, one mechanical the other digital, report 30lbs Is it possible that the TPMS is out of calibration or that my car is pissed that I changed to a different model GY tire
You will gain about 3# when the tires heat up on a normal day if not more. Check them in the morning. The differance between a gauge and the TPS can also be a few pounds. They are not 100% accurate anyway. Thats been my experience anyway. Good luck.
Shouldn't be a problem just from switching the tires. I switched from GS-2 to GS-D3 runflats recently and didn't have any problem. My Intercomp gauge matches the DIC perfectly.
I have four or five tire pressure gages and they all read differently. I just chose to use the one that comes as close to the TPMS reading as possible. That solved my problem. I just try to see an equal amount of pressure on the tires at all times, works pretty close.
Possible scenario: the tires were warmer the first morning, accounting for the 3-pound difference in TPMS readings (when I drive to work in the morning, my right tires read higher pressure than the left tires because the sun is shining on the right side of the car). The difference between TPMS and your handheld gauges could be due to high elevation, because the TPMS sensors aren't referenced to ambient pressure. What's the elevation where you live?
We are at 5K feet. You bring up a good point, my wife followed me to Reno where the tires were installed. The tires were in the back of our pick-up, under the tonneau cover and I'm sure it was at least 100*
At ABQ, at 5000', my TPMS consistently reads 2.5-3 lbs less than several, supposedly accurate, handheld digital gauges.
Tire pressure (relative not absolute) rules of thumb I recall are 10 degree F = 1 psi and 2000' = 1 psi.
That explains everything. Under those circumstances, if the readings weren't what they were, something would be wrong.
