Not using "Invisicord"...?
Old Aug 11, 2008 | 12:34 AM
NVR LAT's Avatar
NVR LAT
Default Not using "Invisicord"...?
I've read a couple threads in the last few days about people "not wanting to use" the invisicord. Is there a legit reason for this? To me it seems like the perfect install...I have one. Why wouldn't someone want "less wiring" and a "neat and clean" install?
Old Aug 11, 2008 | 12:42 AM
headhunter1975's Avatar
headhunter1975
Yeah, I'll give this a bump cause I'm curious about it too. I'm considering the same thing.
Old Aug 11, 2008 | 12:54 AM
adias's Avatar
adias
I have one and it works great. I bought the 8" size but I recommend the 12"instead.
Old Aug 11, 2008 | 01:03 AM
Cal Vert Man's Avatar
Cal Vert Man
If you do a search you'll probably run across a post that discribed a situation where the cord fell out of the plug which could be a disaster because that means the dectector is not working.
Simple fix . . . tie the invisacord to the wire bundle running to the plug in back of the rear view mirror with a zip tie.
Old Aug 11, 2008 | 02:26 AM
leres's Avatar
leres
It's not difficult to run wires down to the passenger fuse box and when you do you have more circuits to pick from. I like the "HTD SEAT/WPR RLY" circuit which is only energized when the ignition is on:
Old Aug 11, 2008 | 04:35 AM
keyplyr's Avatar
keyplyr
No fuse protection would be my guess.
Old Aug 11, 2008 | 05:09 AM
RBLUVETT's Avatar
RBLUVETT
Default Why no Invisacord?
I prefer to have my V1 located in the lower left corner of my windshield. It works just fine there; I've been using that spot for years, and it's not where Leo or thieves would normally look. From outside it is hiding behind the state inspection sticker. I have a piece of black felt glued to the top that further disguises it. When I park some place, say at a hotel at night, I just throw folded up map over it. So for that location, the Invisacord is not the best solution, and would have to be four feet long. I wired mine today with info received on this forum: (use the heated seat fuse) snaked the wire behind the console, under the drivers dash, tucked it along the side of the dash up to the lower left corner of the windshield. Totally invisable.
Old Aug 11, 2008 | 08:38 AM
harddrivin1le's Avatar
harddrivin1le
That's a very good point.
Old Aug 11, 2008 | 08:58 AM
DarthStimpy's Avatar
DarthStimpy
the mirror is on a fuse.
I've been using an "invisicord" for 7 years in 3 different cars and have never had a problem.
(really it's just a telephone cable with two push pins soldered on, oh wait that is an invisicord)
Old Aug 11, 2008 | 09:21 AM
Maizen's Avatar
Maizen
The ISRVM/HVAC fuse which is a 10 amp fuse protects the mirror circuit. And yes its a way bigger fuse than required, but the fuse is not to protect the detector, but rather protect the car's electrical supply.
Old Aug 11, 2008 | 09:26 AM
THE TECH's Avatar
THE TECH
The Invisicord is a total crap item. The two spade terminals that they put on there won't stay connected inside the back terminals of the mirror whatsoever. I had to modify it to get it working properly.
Old Aug 11, 2008 | 09:30 AM
NYC6's Avatar
NYC6
The Invisacord if hooked up according to the supplied directions is only powered up when ignition is on also. And with the visor clip I dont even think about the V1 until the lights go off. Its idiot proof.
Old Aug 11, 2008 | 09:47 AM
Maizen's Avatar
Maizen
Sounds like you didn't get them in right. I agree it seems a little cheap, but I installed mine about a year ago and never lost contact once...not even momentarily!
Old Aug 11, 2008 | 09:59 AM
THE TECH's Avatar
THE TECH
I tried it every which way possible and the connections sucked.
Old Aug 11, 2008 | 10:14 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Well, really....just because you have had problems doesn't mean it sucks, I think MOST people have had no problems with the connection. I didn't even tie wrap mine and it has never come out.....go figure.
Old Aug 11, 2008 | 10:17 AM
THE TECH's Avatar
THE TECH
Just cause it has worked for others doesn't mean it's great either.
Old Aug 11, 2008 | 10:29 AM
T's C6's Avatar
T's C6
Active Streak: 90 Days
To Not using "Invisicord"...?
Old Aug 11, 2008 | 10:40 AM
PolishDude's Avatar
PolishDude
it worked perfectly for me, not even close to falling out, you probably just did it wrong
Old Aug 11, 2008 | 10:56 AM
c6-mike's Avatar
c6-mike
I put mine in and have no problems. It takes a lot of patience but once connected properly it will not come out
Old Aug 11, 2008 | 10:58 AM
User 81424's Avatar
User 81424
Where did you get that fuse thing, what is it called?
