Reverse lights/Back up lights
Old Aug 14, 2008 | 09:18 AM
cylon's Avatar
cylon
Default Reverse lights/Back up lights
Does anyone know if the reverse lights are on a fuse all by them selves? Mine no longer work on my '06 vert and I am hoping it is a fuse. It is covered as I have an extended warranty but I donot want to spend the time in my dealership, although they will do it while I wait
thanks all
norman
Old Aug 14, 2008 | 09:20 AM
danl72's Avatar
danl72
I think they are.
Old Aug 14, 2008 | 09:49 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
thanks all
norman
(The instrument panel fuse block is located on the passenger’s side of the vehicle, under the instrument panel and under the toe-board.)
Old Aug 14, 2008 | 09:59 AM
cylon's Avatar
cylon
Thanks, I will look at it this evening when I get home. I happen to have an extra one that I pulled out out (bottom right) tee hee hee
Old Aug 14, 2008 | 10:02 AM
mksz51's Avatar
mksz51
Could be the fuse - but maybe / likely not (what would make the fuse blow?). Happened on my 2005 also - ended up being the body control module (BCM in GM tech-speak). Could be some other things also (switch on transmission, etc). If not the fuse then you are likely going to have to see the dealer. Good luck.
Old Aug 14, 2008 | 10:22 AM
cylon's Avatar
cylon
thakns
Old Aug 15, 2008 | 08:17 AM
cylon's Avatar
cylon
Not the fuse - off to see the dealer.....
Old Aug 15, 2008 | 08:24 AM
*FAÇADE*'s Avatar
*FAÇADE*
Best of luck - hope they take good care of you!
Old Aug 18, 2008 | 04:18 PM
cylon's Avatar
cylon
u were right, it was the switch, but the part comes from mexico, 2 weeks
To Reverse lights/Back up lights
