Tire pressure ?
When are you checking the DIC as compared to the gauge? The Tire sensors will not update when the car is stationary but once per hour. I would consider getting the pressure set so that all the TPMS readings are at 30 psi cold and then check them with your gauge and you can the see what the handheld reads to compare.
Did you just get the car? Is it new, or did you get it used? Does it have some wheels other than the OE ones on it? Did you put new sensors in it recently?
The only reason the sensors would not be registered with the TPMS computer in your car is if different wheels with a different set of sensors was put on.
If your car has been sitting still for more than 15 minutes, the sensors only transmit once per hour. When you start driving faster than 20 mph the sensors start transmitting once every 60 seconds.
So, if your car has been sitting for a while when you check the pressures with a gauge, you need to drive it faster than 20 mph for a few minutes for the sensors to send the current pressures to the TPMS and get displayed on the DIC.
The DIC is a good reference for a general idea of what your pressures are (actually the sensors are very accurate, but the DIC only displays to the nearest +/- 1 psi, and driving at high elevations makes the display about 2 or 3 psi low). So, check and set your pressures with good gauge.
If you move your sensors (i.e., if you get new tires and they move the one that was on the LF to the RR), if you get new sensors, or if you have a couple sets of wheels/tires/sensors, you need to register the sensors with a tool as in the video below.
Bob
