Widest tires
Old Aug 15, 2008 | 01:28 AM
MeVette's Avatar
MeVette
Default Widest tires
Yes another whats the widest tire that can fit on the stock wheels under the stock body thread. I just want to get a fully faction answer since this is one of the first mods I will do.
I'm looking going 265 on the front and 305 on the rear. I would like to go bigger but I don't want to tub it out or buy new wheels since I have no idea how to do that. Well I know how to buy new wheels I mean the first part. As you can tell I try to be funny but fail most times at it.
Old Aug 15, 2008 | 08:22 AM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Shoot me a PM on what you are looking for brother!
John@AutoBuffs
Old Aug 15, 2008 | 08:50 AM
EvanD's Avatar
EvanD
CF Community Team
There are others that would like to hear the answer too please...
Old Aug 15, 2008 | 10:10 AM
EVRGRN's Avatar
EVRGRN
Something you have to be concerned with is that the larger tire sizes you mentioned are not recommended for the standard wheel widths.
For the front you want to go with a 265. You would have to go with 265/35-18 or 265/40-18 to keep the overall diameter within 2-3% of the original diameter. However, those tire sizes have a minimum recommended wheel width of 9". The stock wheel is 8.5"
For the rear, you want to go with 305. A suitable size in a 305 would be 305/30-19 (I can't find a 305/35-19). However, again that is too wide for the stock wheel. Recommended wheel width for that tire is 10.5", whereas the stock wheel is 10"
Ultimately, can you run these tires on the stock wheels?...yes. However you will be compromising the cornering performance of the tires, and the car.
If you have to have more rubber on stock wheels, the better option would be to go with a more conservative increase to 255/40-18 up front and 295/35-19 in the rear.
Or get wider wheels, check offsets, consider tubbing etc and plan your rubber accordingly.
Old Aug 15, 2008 | 10:16 AM
CQRT's Avatar
CQRT
Just curious why you think you want to change from what the factory designed . . .for looks . . or tracking or just cuz ?
To Widest tires
