Repro wheels
Old Aug 21, 2008 | 07:44 AM
tony 63 vette's Avatar
tony 63 vette
Default Repro wheels
Just wondering if there are any REAL reasons for NOT buying the after-market wheels
Old Aug 21, 2008 | 07:53 AM
ufaj26's Avatar
ufaj26
My own experience with after market wheels has been great. I have purchased a number of sets over the years and have never had a problem with the finish or the roundness. They have worked out fine for me.
I'm sure there are probably some horror stories but I have had no problems with them.
Old Aug 21, 2008 | 08:03 AM
speedraider's Avatar
speedraider
I had some that were out of round. Chrome z06. The goodyear shop showed me on the balancer.
Old Aug 21, 2008 | 08:11 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Which aftermarket wheels? Those made specifically for Corvette? or some cobbled up set with spacers?
Old Aug 21, 2008 | 08:22 AM
tony 63 vette
made for vettes
Old Aug 21, 2008 | 08:25 AM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
I've had good luck with mine.
Old Aug 21, 2008 | 08:27 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
issues have surfaced here on CF to include: chrome peeling, out of round wheels, excessive weights required to balance, non-clearance for big brake package, surface deterioration (either due to clear coat issues or polished-only surface), etc. one of the repeated issues is non-returnability of either wheels or money when wheel doesn't balance, but that's an individual, vendor-specific issue.
and some owners are concerned about the weight of the wheels compared to ultra lite wheels.
Old Aug 21, 2008 | 10:24 AM
MNVette's Avatar
MNVette
There is two schools of thought here. "Aftermarket wheels" can mean two separate things - cheap and REALLY expensive. Most non-OEM wheels for the Vette are in the cheap variety - a few hundred a wheel. They are okay, but they are usually heavier and weaker than stock rims. They're really only good for casual street driving and car shows, and the styles available are quite limited (some play on stock and Z06 looks usually). The expensive wheels are somewhere about a grand each and are high performance wheels that can look as great as you're bank account allows. For example, I happen to like the BBS diamond black rims for the Vette. Even at tire rack, however, a set of 4 rims is going to run about $4,500.00 delivered. Ouch. You can do a lot of performance mods for that kind of money.
Personally, I happen to like the stock rims. To get me to change them, I would have to see a great performing/looking wheel for a lot less money than what the others cost. I'd rather upgrade brakes, etc. with the money.
Old Aug 21, 2008 | 11:03 AM
speedraider
with a pound of weights on each wheel.
Old Aug 21, 2008 | 11:05 AM
Cave Bear's Avatar
Cave Bear
Old Aug 21, 2008 | 11:10 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have had good luck with the ones on my C5 and look forward to getting some ZR1 clones when they come out
Old Aug 21, 2008 | 11:13 AM
NYC6's Avatar
NYC6
The Chinese may do a good Olympics but they make terrible car wheels. Try to avoid inexpensive cast wheels(you get what you pay for). Excellant quality American made forged wheels can be had for less than $4500. I have a set of CCW wheels that I had delivered for about $3200. Do a search on CCW, you will see only people satisfied with the quality and service, then do a search on cheap repro wheels and take note of the many unhappy customers. Do your homework before rushing into it.
Old Aug 21, 2008 | 12:10 PM
CQRT's Avatar
CQRT
Old Aug 21, 2008 | 01:09 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
While I agree that there are some (or even many) wheels from China that are of low quality, the brush to paint all wheels from China as inferior isn't correct. In fact, the largest wheel seller on that internet auction place regularly uses wheels from China.
Like anything, including those items made in America, it all depends on the specs. If you spec a certain quantity and quality of materials in a wheel, that's what you will be receiving as a wholesaler/jobber. This major wheel distributor does their own specs. For instance, while Kenmore is great, it isn't the same thing as a Whirlpool.
I've had their wheels on prior generation Corvettes. Not only were they not heavier than original, they were well made and could stand up to scrutiny.
Old Aug 21, 2008 | 01:15 PM
bonnell's Avatar
bonnell
"Personally, I happen to like the stock rims. To get me to change them, I would have to see a great performing/looking wheel for a lot less money than what the others cost. I'd rather upgrade brakes, etc. with the money."
Old Aug 21, 2008 | 01:16 PM
nwc6's Avatar
nwc6
I had a set of repro wheels on my C5. They had sever chrome peel starting from the inner barrel of the wheel to the outside lip. Every manufacturer makes mistakes, but in this case, the Manufacturer and vendor (forum vendor) would not stand behind their product. Buyer beware!
Old Aug 21, 2008 | 02:40 PM
speedraider
who...
To Repro wheels
Old Aug 21, 2008 | 02:54 PM
C6NRED's Avatar
C6NRED
For most of the wheels out there, you are correct, but I think that there are wheels that fall between the extremes in price that you mention. The CRAY Mantas and Scorpions come to mind, and you have your choice of black, silver or chrome in both styles. For me, they are a great mid price alternative, and mine spun up on the tire balancer very, very well --- even the tire guy complemented them as to how few weights they took and how true they ran.........
Old Aug 21, 2008 | 03:03 PM
MNVette's Avatar
MNVette
True, except that they are far weaker than stock wheels and, unless I was misled by several different sources, heavier than stock as well. They fit into the "cheap" alternative, IMO, since they are only a couple hundred bucks a wheel - you can get an entire set for well under a grand.
NYC6's Avatar
NYC6
Thats exactly what Im talking about. You can do a search and read complaints just like this one ALL Day long! And the vendors dont want to deal with complaints because they get them so often. You dont get complaints like this with quality wheels and CCW for example is known for making things right with their customers if they have a issue rare as it may be. And just because the largest wheel seller on the interweb sells alot of Chinese wheels does NOT make them a good wheel. It just goes to show how many cheap uneducated people there are out there.
