Shift Boot
Old Aug 24, 2008 | 02:07 PM
retaf87's Avatar
retaf87
Default Shift Boot
Has anyone replaced their 6 speed shift boot & ****? If so, how big a job is it?
Old Aug 24, 2008 | 02:11 PM
johnhayesjr's Avatar
johnhayesjr
pretty easy. loosen a screw twist **** and it pops off. need special adaptor for stock shifter if you are using aftermarket ****
Old Aug 24, 2008 | 02:12 PM
danl72's Avatar
danl72
It is not that hard at all. I think the 6 speed has a hex bolt you need to remove under the boot.
Old Aug 24, 2008 | 02:25 PM
retaf87's Avatar
retaf87
Thanks - but really meant replacing the boot as well as ****.
Old Aug 24, 2008 | 02:29 PM
car2fast4you's Avatar
car2fast4you
The boot is also easy to replace.
It has a plastic ring around the inside of the boot that clips into the underside of the console.
You just squeeze inward on the boot with one hand, while releasing the plastic clips with the other.
Just take your time & you won't have any problems.
I used painters tape to protect the console while I switched out the boot.
Old Aug 24, 2008 | 02:34 PM
retaf87's Avatar
retaf87
Thanks for the tips! Thinking about replacing the one in my '06 as I have the cashmere interior with the gray boot and surrounding area. Wonder what GM was thinking with that color combo!
Old Aug 24, 2008 | 02:57 PM
Wayne88's Avatar
Wayne88
This forum vendor has some instructions too, with pictures.
http://www.redlinegoods.com/C6install.shtm
Old Aug 24, 2008 | 03:13 PM
danl72's Avatar
danl72
Old Aug 24, 2008 | 03:43 PM
bapd77's Avatar
bapd77
If you're going to change it, I would consider ds vettes. I have some stuff from them and it is great.
www.dsvettes.com
Old Aug 25, 2008 | 11:37 AM
Les-10's Avatar
Les-10
Bow-Tie Guy
Cake Walk! 15 minutes tops.
Old Aug 25, 2008 | 12:49 PM
ten64's Avatar
ten64
When replacing the shift boot, do you need to remove the center console? or can you remove the boot with the console in place?
Old Aug 25, 2008 | 04:25 PM
car2fast4you
Here's instructions:
http://content.madirect.com/pdf/622872.pdf
Old Aug 25, 2008 | 04:34 PM
MSC6's Avatar
MSC6
You do not need to remove the center console. Like stated above it's very easy.
Old Aug 25, 2008 | 04:38 PM
MSC6's Avatar
MSC6
Bought my 2tone from MAM (Mid America Motorworks). Very inexpensive and it's leather not crap like the stock peice.
Old Aug 25, 2008 | 05:58 PM
Cal Vert Man's Avatar
Cal Vert Man
The cashmere **** and boot looks good . . .
To Shift Boot
