Powder Coating Wheels: The entire Process
So I've decided I could *maybe* save a buck or two and Powder Coat my stock '07 wheels black... It looks like it's going to run me about $320 just for the powder coating here in Las Vegas....However, the process is what's confusing me...
It looks like I'll have to go out and buy a few jacks and jack stands, approx. $250. Is it safe to leave the car on Jacks for 3-4 days while I wait for my wheels to get done? This makes me nervous.
Also, I know the wheels have sensors on them, how does this play in with getting them powder coated?
Thanks for the help, I'm a total noob here, and have zero mechanical skills, so if my questions are rudimentary I apologize.
Thanks for the help!
Yup, you can leave the car up on jackstands, assuming you have then placed in the preferred points (do a search on jacking points.)
When the wheel is broken down, the sensor/valve stem (it is a one piece unit) should be removed. You may want to a couple of valve stem/sensor repair kits hanging around when the tire is put back on the wheel as sometimes the rubber washers were crushed at the factory.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Bear, all good questions. Auto's right; on top of C6 Gen is a section called stickies. In there, there's a section/thread called FAQ. And in there is a lot of info. Here's the one for jacking points: http://forums.corvetteforum.com/show....php?t=1117639
And note that Auto means "breaking down" which is defined as separating the tires from the wheels. If the shop does it carefully and replaces the same sensor to the same wheel that comes off the same location (as in Right Front wheel, Right Front sensor), then the computer for the TPMS (tire pressure monitoring system) won't have to be re-programmed to recognize that the wheel/sensor has been changed.
So, just ask them to mark it or bag it. The fellow who took mine apart and put them back on was careful that way. Really helps.
Good luck!
Good luck!
Thanks for all the help guys....
After a whole lot of hustle I got the wheels down to the powder coat shop.
Should be done tomorrow with any luck! Hopefully my zaino will be here by the weekend and I can put a fresh shine on her and get some pictures up!
Depending on how many miles on yor tires, you may want to swap sides for the tires, effectively rotating them. That is, the inside of the front passenger side tire would be the outside of the front driver side, and the inside of the previous front driver's side would then be the outside of the front passenger side. Same for the rears.
There can not be anything on the wheels, as once the powder is sprayed on the wheels it is sent in to an oven (approx 350-400 degrees or more) for about 45 minutes to cure and bond the powder to the wheel. Any things such as rubber, seals,, electroncis etc would be damaged or destroyed in the oven.
Good luck!
Good luck!
Well I've made my first mistake of many to come! I've got em sitting in a bag right here, not marked...After doing some searches on the forum looks like I'll be off to the dealership to have them reprogram the sensors...Unless I get really lucky and get em on the right wheels.
St. Jude Donor '15
"In honor of jpee"
Hey, we all make mistakes! Every so often we have a "dumb-things-I-did" thread----you should read some of the posts. It's hilarious and makes anything you do seem like sheer genius.
I was reading around, it looks like the magnet trick only works for C5's....
Maybe the local tire shop will have something...Either way I just want to get back on the road. Had to take the explorer to work today, and it was tough getting out of bed.
After 2 days I'm addicted to the 'vette, hope the fun never wears off
