Navigation question
Old Aug 28, 2008 | 12:56 PM
Formula52's Avatar
Formula52
Default Navigation question
Hi All,
I need to know how to cancel a POI while driving without canceling the whole trip. Here is what happened:
Driving with a friend to Carlisle. Wanted to show him how voice recognition worked. Said CD, voice said gas station icons. Well it kept tell me to get off at every exit that had a gas station. Quite annoying. How do I cancel the gas station icons without canceling the whole trip route? Could not figure out how to cancel that. I looked in the book and could not figure it out.
Thanks,
Steve
Old Aug 28, 2008 | 01:03 PM
eyoung13's Avatar
eyoung13
Just say "POI off." It clears those kind of icons.
Just to let you know, if you wanted to cancel the trip, you say "delete destination".
Somewhere in my NAV books was a list of all the commands.
Old Aug 28, 2008 | 01:22 PM
Formula52's Avatar
Formula52
Thank you, That is what I needed to know...
Old Aug 28, 2008 | 01:38 PM
johnodrake's Avatar
johnodrake
Moderator
Here are the voice commands (also in the manual)
Press this talk symbol hard key and release it when you hear a beep. The audio system, if on,
will mute.
2. Clearly state one of the commands listed on the following pages. For example, say "FM1."
3. The system will tell you the command being implemented. For example, the system will say "FM1
Radio" and change the audio system to the FM1 source.
You may end voice recognition by not speaking any commands. After about five seconds of silence,
the system will automatically cancel voice recognition.
At times, the system may not understand a spoken command. If this happens, try again. If a spoken
command is not available, the system will provide feedback based on availability.
While using voice recognition, make sure to keep interior noise levels to a minimum. Otherwise, the
system might not recognize voice commands.
The system will only recognize commands spoken in English.
Voice Recognition Commands
The following list shows all of the voice commands available for the navigation system with a brief
description of each. Any words shown in square brackets are optional. If there are words shown in
parentheses, choose one of the options. To use the voice commands, refer to the instructions listed
previously.
Help Commands
These commands are universal and will enable you to use the help prompts available from the
system.
Command Help/List
This command will enable the system to provide the available commands for the navigation
radio.
Cancel
This command cancels the voice recognition function.
Radio Commands
Radio
This command will change the audio system to the next radio audio source.
AM
This command will change the audio system to the AM audio source.
FM1
This command will change the audio system to the FM1 audio source.
FM2
This command will change the audio system to the FM2 audio source.
XM1
This command will change the audio system to the XM1 audio source.
XM2
This command will change the audio system to the XM2 audio source.
Power On, Audio On
These commands will turn the system's power on.
Power Off, Audio Off
These commands will turn the system's power off.
Seek Up
This command will cause the selected audio source to seek up to the next strongest signal.
Seek Down
This command will cause the selected audio source to seek down to the next strongest signal.
Stop Scan
This command will cause the audio source to stop scanning for the next strongest signal.
CD Player Commands
Track Up
This command will cause the CD player to skip up to the next track.
Previous Track
This command will cause the CD player to go to the previous track.
Track Down
This command will cause the CD player to go to the beginning of the track or go to the
previous track if the counter is less than 9 seconds.
Screen Commands
Screen Day Mode, Day Mode On
These commands will adjust the system's screen setting to the day mode.
Screen Night Mode, Night Mode On
These commands will adjust the system's screen setting to the night mode.
Screen Auto Mode, Auto Mode On
These commands will adjust the system's screen setting to auto mode.
Screen Off
This command will turn the system's screen display off.
Position Commands
Current Position, Current Location, Show Current Position, Show Current Location
These commands will cause the system to display the vehicle's current location on the map
screen.
Map
This command will cause the system to display the map screen.
Map Commands
Zoom In
This command will cause the system to zoom in when on the map screen.
Zoom In Maximum
This command will cause the system to zoom in to the minimum available map scale when on
the map screen.
Zoom Out
This command will cause the system to zoom out when on the map screen.
Zoom Out Maximum
This command will cause the system to zoom out to the maximum available map scale when
on the map screen.
Heading Up, Change to Heading Up
These commands will cause the system to display the Vehicle Up heading when on the map
screen.
North Up, Change to North Up
These commands will cause the system to display the North Up heading when on the map
screen.
Map Direction, Change Map Direction
These commands will cause the system to change the vehicle's direction from North up to
heading up or heading up to North up on the map screen.
Mark, Mark This Point
These commands will cause the system to mark the location as a memory point while on the
map screen.
Right Map Zoom In
This command will cause the system to zoom in on the right map when in dual map mode.
Right Map Zoom In (Maximum/Minimum Scale)
This command will cause the system to zoom in to the minimum available map scale on the
Right Map Zoom Out
This command will cause the system to zoom out on the right map when in dual map mode.
Right Map Zoom Out (Maximum/Maximum Scale)
This command will cause the system to zoom out to the maximum available map scale on the
Right Map [Change to] / [Show] North Up [Mode]
These commands will cause the system to display the North Up heading on the right map
when on the map screen in dual map mode.
Right Map [Change to] / [Show] Heading Up [Mode]
These commands will cause the system to display the Vehicle Up heading on the right map
when on the map screen and in dual map mode.
Right Map [Change Map] Direction
This command will cause the system to change from North Up to Heading Up or from Heading
Up to North Up.
[Show/Change to] Dual Map Mode
This command will cause the system to change the map display to dual map mode.
[Show/Change to] Single Map Mode
This command will cause the system to change the map display to single map mode.
[Change to] 3D Map [Mode]
This command will cause the system to change the map display to the 3-dimensional map.
[Change to] 2D Map [Mode]
This command will cause the system to change the map display to the 2-dimensional map.
Destination Commands
Home, Go Home
These commands will cause the system to enter the Home destination as a waypoint or final
destination, if one is set.
Go to Starting Point, Previous Starting Point
These commands will cause the system to enter the last available starting point as a waypoint
or final destination.
[Go to] Previous Destination
This command will cause the system to enter the last available destination as a waypoint or
final destination, if one is available.
[Go to] Preset Destination [Number] (number)
This command will cause the system to go to the preset destination number. This preset
destination can be chosen as a waypoint or a destination. There must be a location stored in
the preset destination number that is chosen. For example, first store a location in Preset
Destination 3. Say "Go to Preset Destination 3." The system will go to Preset Destination 3 and
prompt you to choose it as a waypoint or destination.
Add [to] Waypoint
This command will cause the system to add the current marked point as a waypoint. This
command is used after the following commands have been used: Home, Go to Starting Point,
Go to Previous Destination.
Enter Destination
This command will cause the system to add the current marked point as the final destination.
This command is used after the following commands have been used: Home, Go to Starting
Point, Go to Previous Destination.
Guidance Commands
Repeat Guidance, Repeat Voice
These commands will cause the system to repeat the last available voice prompt guidance
command if a destination has been set.
Louder
This command will cause the system to increase the volume of the navigation voice prompts.
Softer
This command will cause the system to decrease the volume of the navigation voice prompts.
Voice Guidance Off
This command will cause the system to turn off the navigation voice prompts if a destination
has been set.
Voice Guidance On
This command will cause the system to turn on the navigation voice prompts.
[Change to] Arrow (Guide/Guidance)
These commands will cause the system to change to Arrow Guidance screen view in the
Guidance Menu if a destination has been set.
[Change to] Turn List (Guide/Guidance)
These commands will cause the system to change to Turn List Guidance screen view in the
[Change to] Freeway (Guide/Guidance)
These commands will cause the system to change to Freeway Guidance screen view in the
Guidance Menu if a destination has been set. This command is only available if you are on a
freeway.
[Change to] Intersection (Guide/Guidance)
These commands will cause the system to change to Intersection Guidance screen view in the
Guidance Menu if a destination has been set. This command is only available when the next
turn is less than 0.5 mile (800 m) away for city streets and 2 miles (2 km) away for freeways.
Entire Route, Entire Rout Map, Route Overview
These commands will cause the system to display the entire route if a destination has been
set.
Reroute
This command will cause the system to generate an alternate route to a set destination while
on a planned route.
Detour, Detour Entire Route
These commands will cause the system to activate the detour feature when driving a planned
route.
Next Waypoint Map
This command will cause the system to display the map view of the next waypoint location if
one has been set.
(First/Second/Third/Fourth/Fifth) Waypoint Map
This command will cause the system to display the map view of the named waypoint location
if it has been set.
Destination Map
This command will cause the system to display the map view of the final destination location if
one has been set.
Yes
This command will confirm system talkback.
No
This command will cancel a command.
(Delete/Cancel) Destination
This command will cause the system to cancel the current destination.
(Delete/Cancel) All Waypoints and Destination
This command will cause the system to cancel all currently set waypoints and the final
destination.
Quick
This command will cause the system to select the Quick route when a destination has been
set.
Normal
This command will cause the system to select the Normal route when a destination has been
set.
Short
This command will cause the system to select the Short route when a destination has been
set.
Point of Interest (POI) Commands
The following commands will cause the system to display icons if they are available on the map
screen when the map scale is set to ½ mile (1 km) or less.
Automobile Commands
· Auto Service And Maintenance, Auto Service, Maintenance
· Automobile Club, Triple A
· Car Park
· Car Wash
· Gas Station, Gas
· Other Automotive
· Parking
· Parking Garage
· Parking Lot
· Rental Car Agency
Entertainment Locations
· Amusement Park
· Botanical garden
· Campground
· Casino
· Cinema
· Golf Course
· Horse Racing
· Marina
· Museum
· National and State Parks
· Park & Recreation, Parks & Recreation
· Performing Arts
· Ski Resort, Skiing
· Speedway
· Sport Complex, Stadium
· Tourist Attraction
· Video Rental
· Winery
· Zoological garden
Financial and Government Offices
· ATM
· Bank
· Business Facility
· City Hall
· Civic Center, Community Center
· Convention Center, Exhibition Center
· Court House
· Government Offices
· Higher Education, University, College
· Hospital
· Library
· Other Financial Services
· Police Station
· Post Office
· School
· City Center
Personal Services
· Beauty and Barber Shops
· Dry Cleaning
· Health and Fitness Club
Restaurant Locations
· American Restaurant, American Food
· Chinese Restaurant, Chinese Food
· Coffee House
· Continental Restaurant, Continental Food
· French Restaurant, French Food
· Ice Cream Parlor
· Italian Restaurant, Italian Food
· Japanese Restaurant, Japanese Food
· Mexican Restaurant, Mexican Food
· Other Restaurant, Other Food
· Restaurant, I'm Hungry
· Seafood Restaurant, Seafood
· Show Restaurant
· Thai Restaurant, Thai Food
Shopping Locations
· Convenience Store
· Department Store
· Grocery Store
· Home and Garden
· Other Retail Store
· Pharmacy
· Shopping, Shopping Mall
· Specialty Food Store
Transportation
· Airport
· Bus Station
· Ferry Terminal
· Historical Monument
· Hotel
· Park & Ride
· Rest Area, Rest Stop
· Tourist Information
· Train Station
POI Off
This command will cause the system to turn off POIs so they do not appear on the map screen.
Old Aug 28, 2008 | 01:40 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Holy Crap Batman! Longest post I've ever seen!
Old Aug 28, 2008 | 01:42 PM
johnodrake's Avatar
johnodrake
Moderator
Mosey over to PR&C if you want to see long posts
Old Aug 28, 2008 | 03:21 PM
Bobz08C6's Avatar
Bobz08C6
memorize these commands. There will be a pop quiz tomorrow.
There are just too many to be practical. I memorized a few but my feeble mind overheats if I try to memorize more than a few. There is a quick reference card you can keep in the center console for your passenger to look up.
Old Aug 28, 2008 | 07:21 PM
johnodrake's Avatar
johnodrake
Moderator
I just memorize the ones I need to work then try like heck (usually without success) to get the system to understand me. The worst feature on the car is the voice recognition system...
Old Aug 28, 2008 | 08:23 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Here are the commands that I have learned and use:
Command Help Memorize this one and you don't need a cheat sheet in the console.
AM, FM1, FM2, XM1, XM2, CD Is that so hard to remember?
Seek Up, Seek Down, Stop Scan You don't need these when you have buttons on the steering wheel that do the same thing.
Track Up, Previous Track, Track Down Again, just use the steering wheel buttons.
Screen Day Mode, Screen Auto Mode You always want auto mode except vary rarely the it will decide it is a little dark and go to night mode which is hard to see if it isn't night.
Screen Off NEVER use this command. Try it and you will find out why. Hint: Where is Screen On?
Zoom In, Zoom Out To change detail.
Dual Map Mode, Single Map Mode To change map modes.
Preset Destination [Number] Contrary to popular belief you CAN set destinations while driving as long as you have entered it before and saved it in one of the 100+ available slots. You just have to remember the numbers.
Repeat Guidance No, "HUH?" is not a valid command.
Louder, Softer When the tires get worn and noisy.
Voice Guidance Off, Voice Guidance On This isn't rocket science!
Turn List A very valuable mode!
Freeway Seems to be a default when you are on the Interstate. Good when the gas gauge says you must stop NOW!
Detour When you see a lot of brake lights ahead.
Quick, Normal, Short You MUST understand the different routings if you are ever going to appreciate the power of this device! I use all three often.
Auto Service, Gas, Parking, Hospital, Police Station, Airport, Rest Area I hope I don't lose my Man Card for admitting I know these commands.
Restaurant for all food and (country) Food if I'm feeling picky.
And finally POI Off to answer the original question.
Yes, there are a lot more but I haven't found a need for them. BTW, I speak slowly and enunciate each word and get well over 95% recognition.
Old Aug 28, 2008 | 08:28 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
okay boys and girls ~ there will be a test tonight at 9pm PST.
To Navigation question
