Rim/Tire help
Old Aug 29, 2008 | 06:41 AM
Sportsdude's Avatar
Sportsdude
Default Rim/Tire help
Anyone know why the tire is like that around the lip and not flushed like the one next to it? Rim is 20x12, tire is 335/30/20.
Old Aug 29, 2008 | 07:43 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
the first thought that comes to mind is either rim protector or tire too wide for wheel. someone will comment on this.
that doesn't seem to be the case. is it on properly (correct side facing out)?
just checked tirerack; sez rim size correct for tire size.
therefore, I go back to wrong side of tire on outside? altho fr. the pic above, it appears to be mounted correctly (it is asymetric with diff compounds outside to inside of tire). see center pic: http://www.tirerack.com/tires/tires....3YR0SPORTPS2N0
I don't know. I'd send it to Michelin tech and ask them if no one else has a good answer and the tire's mounted correctly.
Old Aug 29, 2008 | 08:15 AM
push's Avatar
push
Looks a front rim and a back rim. The back rim looks like it has more tire stuffed on it so more 'rim guard'. The front wheel looks to have a smaller tire on it so it doesn't portrude as much.
Old Aug 29, 2008 | 01:13 PM
Sportsdude's Avatar
Sportsdude
I haven't seen a rim saver that protrudes out like that before. Front is 275/30/19 on 19x9.5
To Rim/Tire help
