AVIC-Z3 Installed!
Could you send me some of those screen sweating backgronds?????
RLTW
Product Details
GMAH24B
Category: Radio Replacement
Important Vehicle Compatibility Notes
Click here for Vehicle Compatibility Notes
Jump to:
Product Overview
Product Description
Product Features
Instruction Manual
See More Applications:
See all applications for the GMAH24B
Contact Peripheral:
Get more information on the GMAH24B
» Vehicle Compatibility Notes
MSRP: $169.95
Product Overview
Radio replacement interface for select GM Bose/Premium amplified vehicles to retain On-Star
ˆ Top of Page
Product Description
OnStar® and Class-2 Data-bus Interface for select late model (00-08) GM vehicles with Class-2 radios with OnStar® and BOSE® sound systems.The GMAH24B decodes chime signal commands on the Class-2 data-bus and supplies the appropriate warning tone (door ajar, seat belt, low oil pressure, hi-temp., low fuel, etc...) through the OE amplifier, external speaker, or through add-on chime module GMAHCM (sold separately).
Provides an effortless and seamless head-unit installation into late model GM vehicles while retaining operation of factory features!
ˆ Top of Page
For vehicles that have a "Premium Bose®" amp that only accepts 2 channel audio inputs. OnStar® volume can be controlled via the steering wheel audio controls. The GMAHCM chime module is not required when using the BOSE® amplifier. If you are not using the BOSE® amplifier, then the GMAH24 and GMAHCM interfaces are required. The aftermarket radio will not fade, however it will still continue to balance.
Currently not compatible with 2009 vehicles that are equipped with O.E.M. Bluetooth.
ˆ Top of Page
Product Features
Retains complete OnStar® functionality & features OnStar® volume control via steering wheel controls (in Premium BOSE® system only)
Provides proper audio integration with either; Premium or Standard BOSE® sound systems
Generates 12-volt accessory output & retains RAP function
Uses genuine Delphi chip for seamless integration
Provides “Healthy Status” report to the Class-2 system
ˆ Top of Page
Feature Bullets (Catalog)
Retains complete OnStar® functionality & features OnStar® volume control via steering wheel controls (in Premium BOSE® system only) Provides proper audio integration with either; Premium or Standard BOSE® sound systems Generates 12-volt accessory output & retains RAP function Uses genuine Delphi chip for seamless integration Provides “Healthy Status” report to the Class-2 system
ˆ Top of Page
Instruction Manual Link(s) *Requires Adobe Acrobat
Click here for the GMAH24B instructions
RLTW
On all Z3s, its the later 2 wire bypass and is simple:
http://www.sminntech.com/z1flash.html#newbypass
