Thinking of buying chrome wheels for my 06 Z51 equipped coupe. The offset listed for these wheels is +58mm front and +68mm rear. Will they fit? Thanks in advance!
12 mm is about 1/2 of an inch. Depending on how wide the wheels are (if they are the same overall width as the stock ones??) they should fit just fine. The rear wheels are going to stick out a bit more that the stock ones do. My rear wheels are 19X10.5 with a 65 mm offset, and with the stock tires, they fit (just barely) flush with the outside edge of the fender.........I like the look as it fills the fenderwell much better than the stock offset does.
Thanks for the info! The wheels are 9.5 inches front and 10 on rear if that will make a difference as I really don't want the wheels outside the fenders.
