Where is it stated in the manual? I thought this also until I looked at HPtuners and it shows that the A/C compressor does not turn off. There have been other threads concerning this and the conclusion was it does not turn off.
I, too, thought it was in the manual, but I've looked at both the 2006 owner's manual and the 2007 owner's manual and I can't find it.
I don't think it will shut off automatically if you hit the throttle hard under any circumstances.
Yes In gear WOT will disengage the A/C compressor.
This is correct. Here is the excerpt from the service manual. I've highlighted in bold the relevant text.
The A/C system is engaged by selecting any switch on the HVAC control module except the, A/C OFF switch. The A/C switch will illuminate, A/C OFF, when the A/C switch is selected. The HVAC control module sends a class 2 A/C request message to the body control module (BCM) for A/C compressor clutch operation. The BCM must communicate with the ECM in order for the A/C clutch to be engaged. The HVAC system uses a compact variable swash plate compressor. The following conditions must be met in order for the ECM to turn on the compressor clutch from the HVAC control module request:
BCM will allow A/C operation if the following limits are within normal operating range
A/C line pressure
A/C refrigerant low temperature
Ambient temperature
Engine coolant temperature
Battery voltage
HVAC control module
OAT temperature more than 1.5°C (35°F)
Control module operating range 9 and 16 volts
ECM
Engine coolant temperature (ECT) is less than 128°C (262°F)
Engine RPM is more than 0 RPM
A/C pressure is between 2850 kPa (413 psi) and 204 kPa (30 psi).
Once engaged, the compressor clutch will be disengaged for the following conditions: Throttle position is 100%
A/C pressure is more than 2850 kPa (413 psi)
A/C pressure is less than 204 kPa (30 psi)
Engine coolant temperature (ECT) is more than 128°C (262°F)
