Reading Dipstick
Old Aug 31, 2008 | 08:51 PM
retaf87's Avatar
retaf87
Default Reading Dipstick
I know this issue has been raised numerous times, but after checking my oil today came to the conclusion that the GM dipstick markings have to be some of the worst I have seen in my nearly 50 years of owning cars. With all the technology out there, you would think someone could come up with a way to electronicly monitor the oil level. (Don't consider the oil life span to be same as the level.) I seem to remember when I was a LOT younger that once we determined where the full level was we put a white paint mark on the dipstick. Hmmmm
Old Aug 31, 2008 | 08:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
What works for me is to pull the stick immediately after shutdown, wait about 5 minutes while I pump gas or whatever, then check the oil level. That allows oil to drain down out of the dipstick tube.
The car also is supposed to give you a DIC warning if the oil gets more than about 1 qt low, but mine burns virtually no oil and so that hasn't been a factor for me.
Old Aug 31, 2008 | 09:02 PM
retaf87's Avatar
retaf87
I checked mine while engine was cold so should have drained down, but thanks for the tip.
Old Aug 31, 2008 | 09:06 PM
Gearhead Jim
St. Jude Donor '13
The manual claims that you can only get a valid stick reading when the oil is hot, but at least on my previous C5, hot and cold were within about 1/8" on the stick.
Old Aug 31, 2008 | 09:27 PM
retaf87's Avatar
retaf87
Thanks Gearhead.
Old Aug 31, 2008 | 09:32 PM
Beezvette's Avatar
Beezvette
I read a while back (on the forum) that if you rub some sandpaper to rough up the bottom of the dipstick, the oil will stick to it better. I never tried that, but I have found that I get a better reading when cold, and I remove the dipstick and rub it hard with my cloth, then check the oil level. But any way you do it, it is never a clean read. My Toyotas work the way they should, maybe it is the synthetic oil.
Old Aug 31, 2008 | 09:54 PM
retaf87's Avatar
retaf87
I think the real issue is the design of the dipstick rather than the oil as I had no problems reading the level in either my recent Mustangs or the 92 Vette I drove until 2007.
Old Aug 31, 2008 | 10:11 PM
Boomer111's Avatar
Boomer111
Worst dipstick ever, 06 350Z. The 07 with new engine is a big improvement.
The 06 had a lot of curves and bends, pain just to replace it in the tube.
Old Aug 31, 2008 | 10:22 PM
RnLi's Avatar
RnLi
Dipstick for oil ????? You mean YOU need to manually check the oil level. I thought everything is automatic !!!!!
Just kidding.......
Old Aug 31, 2008 | 10:23 PM
calemasters's Avatar
calemasters
The LS2 and LS3 have a low engine oil level sensor.
To Reading Dipstick
