Need some help from the guys who have their jacks and have a question about the jack's actual "maximum extention" height (for a change). As well as having a low profile (for a Z51) and is extra long to be able to reach the cross member from the front, when I choose. I've searched and read about the different ones but maybe missed the max. heights of them.
Anyway, ordered Race Ramps XT's and the 10" wheel cribs as well (so that the level will be even). Anyway, for oil changes, the ramps will be up front and I'll be jacking the rear for the use of the cribs. By my simple measurements, it looks like it's about 8" from floor up to the rear cross member. I'll need a jack that would have an extention of 18+" to slide the cribs under the tires (they have a slight concave to them for seating), correct? Or, I suppose I could use a 2x4 block for the additional required height.
I've read all about the Omega (know it's a good jack but very heavy and over $200, I believe) and other good, albeit pricier ones. But I was looking at the jack sold by Harbor Freight (U.S.General's 3000 lb. 91039-9VGA $99.00) that some have said is a good lightweight racing jack and would do the job and at a good price. AutoZone sometimes has it as well, they've said. It's max height is only 14-3/4" however, but they also have a few others by that name. Next two 3000 lb. models are also lightweight racing jacks and are respectively more ($159 and $179.). Both of these have a max height of 17-1/2". The last one is a 4000 lb lightweight racing jack at $200. with max height at 18-1/4".
What would be the thing to do? If I go with this brand and they can correctly reach from the front, would it be logical to go with the 18-1/4" model or could I get by with the two 17-1/2" ones? Checked at the local AutoZone, Sam's, and PepBoy's and none have these. Any suggestions and thanks for your help.
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Mine (Costco Aluminum) is currently under the car, but I will measure the max and min heights later if you want me to. Seems like it went to 19" and change, but I did not keep the box.
However, I don't think that it will reach my front crossmember from the front, and this on a non-lowered C6, not Z06, so I might not be helping you at all.
All in all a nice jack for about $100. Finally got rid of my old POS one.
Thanks Kevin. I've read about the one Cosco sells, as well and the one I'm looking at is similiar (all pretty good). I started thinking about the "cribs" I'll be using though and that's when I knew I'd need the tires to clear the 10" height mark. It would not be so much of an issue if I were to just be using stands or just the jack by itself. But since I have the cribs coming, it is.
Craftsman 2-Ton Aluminum jack is 19.75" max height w/Northern Tool Crossmember on board. This will reach the preferred lift points both front and rear. It was $189 when I bought it.
Thanks. I looked at what some said about the Craftman's also. Some liked them, some said they leaked or failed (but not sure which models they were and if wasn't the jacks fault anyway). You like yours, I guess, and it meets my criteria too. I'll look into it as it can be bought locally, I'm sure, instead of ordering.
I just bought the Craftsman Speedylift 2 ton floor jack, it's 3 3/4" to 18 1/2". It works great for me on my Vettes. It was on sale for around $190.00.
Is it low and long enough to reach from the front?
I am pretty sure that is the same thing as what I posted above. The difference in the height is the addition of the Northern Tool crossmember. One thing to note is that there is a small modification necessary to be able to use the Northern Tool crossmember. It's not difficult at all, which is proven by the fact I did it.
Both my C5 and C6 have been lowered so I can't come from the front. If I line it up from the side it looks like it is not long enough without the bar hitting the front to jack it up. I'll go out and measure the length of the jack for you and let you know.
You are probably right. I think the jack normally sells for $220 or more, but I always wait for the sales or the coupons. I think it's a great jack for the price.
Is it low enough, no. But I don't believe any jack can fit under the front without a little assistance. I use the Race Ramps Trak-Jax, which are 3" high (I suspect most use 2X10's), and plenty of height to get the jack with crossmember under the front. It may fit under the back with no assistance. I always use the 3" assist, but I will have to try it without to see if it really needs the extra height.
Is it long enough, yes. Plenty on the back, and just barely on the front.
Ist it long enough, yes. Plenty on the back, and just barely on the front.
It's just about 18 1/2" from the center of the lifting point of the jack's pad to the moving part of the lifting bar (sorry I don't know if I am confusing you more with the use of my wording here).
Hope this helps, but I think it will be to short for you.
That's what I love about this forum, people like you
You can effectively add "lift" by placing a piece of wood (e.g. 4" X 4") between the jack's lifting cup and the frame. It's generally a good idea to have a block of wood there anyway, since it reduces the likelihood of the jack damaging the aluminum cross-members it will be pushing against.
Doing that will dramatically increase your options in ramp choices.
That's what I figured. I don't really won't to invest more $$ on the adaptor since the vette won't really be sustained in the "up" position by the jack (only using it to get it on the cribs).
I admire your ability to use reason on a Vette related project.
Too often, we tend to end up on a spending binge to solve a problem, whether it is real or imagined.
