Handle on hatch
Old Sep 6, 2008 | 05:53 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by Modshack
You should probably not put air in your tires either as it will dilute the original Bowling green Oxygen......
At least it's functional now (as intended originally) without a stupid useless cut-out in the hatch cause they were too cheap to re-tool the panel.....
Wow Steve,
A little harsh, no?
Old Sep 6, 2008 | 06:03 PM
Modshack's Avatar
Modshack
Originally Posted by talon90
Wow Steve,
A little harsh, no?
Yeah, Maybe...Wagging a finger at me because I drilled a hole is a bit ridiculous though......I'm not a preservationist I guess....
All my mods are functional improvements and sometimes require drilling or cutting to achieve the desired result.....so far they've done nothing but improve the car...Others may have a different opinion (apparently!)
Old Sep 6, 2008 | 06:17 PM
talon90's Avatar
talon90
NCM Ambassador
The work you do on your car is alwsays well done, well thought out and the innovation is seldom short of amazing. You also of course realize that it is not for everyone. Remember, there are car owners, car enthusiats, Corvette owners and Covette enthusiasts. One does not equal all and all mods certainly aren't for everyone. There are a great many Corvette purists out there and frankly, I'm kind of glad they are as there will always be original examples of great cars for us to see later in the years.
The other part that made me curious was that shortimer hadn't quoted you. I know that you were the one that talked about drilling but he may very well have been simply saying to the OP that he wouldn't do it. Not everyone means and says the same thing with the use of smileys.
Old Sep 6, 2008 | 06:22 PM
patton's Avatar
patton
St. Jude Donor '09
ive got it on my 07 z but never used. i always thought it wasnt a good idea,it looked like a finger catcher or breaker
Old Sep 6, 2008 | 06:54 PM
C6CPA's Avatar
C6CPA
The handle is a pretty high-tech part, and installation if very involved. The GM engineers worked for years to get that handle design just right, and once they did, studies later revealed that using it caused tennis elbow and shoulder injuries in a number of owners. After settling class action lawsuits brought on by a group of NYC lawyers, GM elected to make a production change in the 2007 model to eliminate this complicated part, even while knowing that they would thus never recoup the cost of design and development of the handle used on the 2005 and 2006 editions. If you have a 2005, 2006 or early production 2007 coupe, your car is worth thousands more by have the OEM handle installed. Such cars should become collectors favorites in the years to come.
Old Sep 6, 2008 | 10:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My car has the handle, I put a piece of white tape on it so it's easier to find in the dark. Cheap, easily removable if desired, and surprisingly useful.
Old Sep 6, 2008 | 10:47 PM
RadarP3C's Avatar
RadarP3C
Oh, well, I guess I've ruined my increased value by adding the mods I've done so far....
Old Sep 10, 2008 | 01:02 AM
Z06BAD's Avatar
Z06BAD
This is what I had in mind when I first asked, I won't install it because I want it to be functional not just bling.
Old Sep 10, 2008 | 07:37 AM
Mad*Max's Avatar
Mad*Max
Originally Posted by Z06BAD
Can anyone tell me why the 07's don't have this handle?
My '07 has a handle...
Old Sep 10, 2008 | 09:30 AM
vinsong's Avatar
vinsong
My '07, built 12/06 has the handle.
Old Sep 10, 2008 | 09:44 AM
j_digi454's Avatar
j_digi454
Originally Posted by RobVette
My 07 has it.
Mine too.
Old Sep 10, 2008 | 10:11 AM
FM's Avatar
FM
Only if they still have the original Bowling Green air in the tires.
