Help installing e-brake cap. Need instructions
Old Sep 8, 2008 | 12:55 PM
VamPY's Avatar
VamPY
Default Help installing e-brake cap. Need instructions
Guys,
I just received my e-brake cap from APSIS and would like to know what is the best way to go about installing it. Do I need to take the e-brake boot off? Shall I use the same instructions as when installing a new e-brake boot?
Appreciate your help
Saied
Old Sep 8, 2008 | 01:20 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
All you really need to do is pull the boot down and uncover the screw that holds the e-brake handle on. Remove the screw and pull up on the e-brake handle. It may take a little force to remove the handle. Now you can change the button, put the e-brake handle back on, put the screw back in and pull the boot back up. Pulling the boot back up may be the hardest part.
Good luck.
Old Sep 8, 2008 | 03:29 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Here you go:
http://www.theredlion.us/DSV%20ebrak...%20install.pdf
Old Sep 8, 2008 | 04:57 PM
VamPY's Avatar
VamPY
Thanks ByByBMW and Paul, will do it tomorrow and post pics
Old Sep 8, 2008 | 04:59 PM
danl72's Avatar
danl72
Good luck.
To Help installing e-brake cap. Need instructions
