Not all Nav discs are made by the same company. The C6 nav system uses a database generated from Teleatlas data, whereas several other systems use databases that are based off of Navteq data. If the database you have in a Cadillac case is made for a Nav radio by the same supplier to GM it may be usable. Using a Navteq database from an Escalade will not work in the C6.
