Wierd Door / Window Problem...
Old Sep 14, 2008 | 06:46 PM
asby69's Avatar
asby69
Default Wierd Door / Window Problem...
I have an 08 Coupe, 3LT, NPP and recently had something wierd to happen and was wandering if anyone else has experienced the problem.
My car sat outside in the wonderful weather of South MS for a couple weeks (while my unit helped with Hurricane Gustav relief in LA) and when I got back, the passenger door would not open from the outside (it would from the inside with no problem). Then the window (same door) started continously going up and down (only the path/length of that it does when it's indexing for the door to open/close), the only way to get it to stop was to keep trying to roll it down with the control on the drivers door and not attempt to roll it all the way up. After a while the window wouldn't roll up all the way. The next day the door started opening from the outside but the window kept going up and down (as previously stated) when entering/exiting the car).
While this was happening, my M2W would not work?!??
A few days went by and now it seems to be OK and the M2W is working correctly. Anyone have any ideas?
If I take it to the dealer now I'm sure they won't be able to recreate the issue and it'll be a wasted trip.
Thanks for the help!
Old Sep 14, 2008 | 06:52 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
First blush tells me that you need a new passenger door switch. It is a very, very easy install. It would contribute to both the door not opening from the outside as well as the window index issue. The switch is not terribly expensive as I recall. You could consider replacing it yourself if you don't have confidence in your dealership.
Old Sep 14, 2008 | 07:02 PM
Red Cell's Avatar
Red Cell
I'm not sure this helps, but my mild to wild works on/off. I went to the dealer and wouldn't you know it...it decided to work. It's properly grounded so it's a mystery to me (and them).
Red Cell.
Old Sep 14, 2008 | 07:30 PM
cclive's Avatar
cclive
This bulletin says to replace both door switches, even if only one is causing the problem..:
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Conti
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)Models: 2007-2008 Cadillac XLR2007-2008 Chevrolet Corvette ________________________________________ ____________________________________This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).___________________________ _____________ ___________________________________Condi tionSome customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.CorrectionDiagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.Parts Information Part Number Description10446243 Front Side Door Handle SwitchWarranty InformationFor vehicles repaired under warranty, use: Labor Operation Description Labor TimeN9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
Good Luck! (my bold emphasis)
Old Sep 15, 2008 | 06:42 PM
asby69's Avatar
asby69
Thanks for the info. I'll get up with my dealer (they have been nothing but great with the 07 Vette that I had) and let them look at it.
Old Sep 15, 2008 | 07:14 PM
cclive's Avatar
cclive
Print it and take it with you...
Old Sep 15, 2008 | 07:18 PM
danl72's Avatar
danl72
Old Sep 15, 2008 | 10:22 PM
JLB768's Avatar
JLB768
My 08 Z06 did that a couple weeks ago, except the door opened fine from the inside, and out. The drivers side window would continuously index up/down when the door was shut. I finally managed to roll the window down, then up, and it was fine after. I had just finished washing it with my pressure washer, and wondered if that had something to do with it. Hasn't done it since...
Old Sep 16, 2008 | 01:04 AM
JLB768's Avatar
JLB768
Spoke too soon. As I stepped into the garage, heard a noise, sure enough, my driver window was indexing repeatedly. Washed it today, coincidence? Looks like I'll be calling the dealership tomorrow. Not worried, shat happens, and it should be an easy fix.
Old Sep 16, 2008 | 11:26 AM
cclive's Avatar
cclive
Again, print it and take it with you...
Old Sep 20, 2008 | 09:27 PM
asby69's Avatar
asby69
The day after this post I received a recall notice for the keyless access system not working (or something like that). I took the Vette to the dealer and they said that they had to order the part to fix the recall issue and that it (the recall issue) was causing the problem. Supposed to be fixed next week.
To Wierd Door / Window Problem...
