Inner fender push-pull fasteners
Old Sep 17, 2008 | 06:33 PM
Vinnie T's Avatar
Vinnie T
Default Inner fender push-pull fasteners
Recently took the inner fenders off for fog light and side cove screen installs. About half of the fasteners were hard to get open and got a little dinged up. Would like to replace those that didn't open cleanly but don't want to pay $2/each at the local dealer. Noticed several online companies that sell these fasteners for $5-$8 for a bag of 25, but there appears to be 3 possible matching part numbers and I can't figure out the right one. When I called the dealer, they weren't sure on the correct part number and asked that I bring a sample in to match it. I know it's an odd part to be asking about, but does anyone know which part number might be correct?
Possible part numbers:
21075686 - the likely match
21077123
21030249
Old Sep 17, 2008 | 07:03 PM
MARSC6's Avatar
MARSC6
I just ordered some of these.
Thefastenerwarehouse.com
Item TR 205 is a perfect match
$6 for 25
You need a $10 minimum order so you might also want to check out the chrome trim screws. $5 for 50 #8 x 1" screws.
Old Sep 17, 2008 | 10:25 PM
Vinnie T's Avatar
Vinnie T
$6 for 25
Thanks! I found their website after I posted this question. I had it narrowed down to that TR205 and a TR240(?) as being the right one. Thanks for comfirming the TR205 for me. Now I'll need to see what else I can buy to get to $10 as I already have stainless body screws. Maybe I'll get some of the push on trim fasteners since those always come in handy.
Can you believe $2 per at the dealer for those fasteners!
Old Sep 17, 2008 | 10:44 PM
MARSC6's Avatar
MARSC6
The TR 240 is for a 1/4" hole.
The TR 106 push in retainer is a pretty good match. The head is the same but the stem has a different pattern.
Old Sep 17, 2008 | 10:49 PM
St.Char's Avatar
St.Char
I would also recommend that you invest in the tool to remove those fasteners. About 5 bucks your local auto parts store.
Old Sep 17, 2008 | 10:52 PM
GotVett?'s Avatar
GotVett?
Better than the cutters, no doubt?
Old Sep 18, 2008 | 06:53 PM
hogan35's Avatar
hogan35
What the tool called?
Old Sep 18, 2008 | 06:56 PM
fastskyline's Avatar
fastskyline
flathead screwdriver and needle nose pliers
To Inner fender push-pull fasteners
