Three beeps when opening door????
Old Sep 20, 2008 | 07:59 AM
StanNH's Avatar
StanNH
Default Three beeps when opening door????
With my number two fob, I get three beeps from the car whenever I open the door. I've gone through the settings for fob 2 and have the fob reminder off. Auto unlock is enabled, auto lock is not. I do not get this with fob 1. The two fobs are not in my pocket together when this happens. Everything functions normally, as far as I can tell, although the trunk sometimes won't open by pressing the outside release with this fob. There are no low battery or exit warnings and the car starts fine with it.
Any ideas about what might be causing the three beeps? It is annoying. If I can't figure it out I'll let my dealer take a look at it.
Old Sep 20, 2008 | 08:14 AM
tom3257's Avatar
tom3257
Hey Stan, I wish I could help. I saw your avatar and thought I would say Hi. I grew up in Wolfeboro on the lake...Been living near Knoxville now for about 15 years though. I sure do miss it up there....Good luck with your problem....tom3257
Old Sep 20, 2008 | 08:44 AM
Gordon Shumway's Avatar
Gordon Shumway
Stan...Did you check to see if you had a Jewel CD in the player?
Old Sep 20, 2008 | 08:49 AM
StanNH's Avatar
StanNH
That would be unlikely, at best.
Old Sep 20, 2008 | 08:54 AM
StanNH's Avatar
StanNH
Developement in the Wolfeboro area has been huge over the past 15 years...you probably would have a hard time recognizing it now.
Just getting into the start of foliage season now. We had two hard frosts the last two nights, so the colors should start popping this weekend.
Old Sep 20, 2008 | 09:15 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Read chevtech's post here:
http://forums.corvetteforum.com/show...post1566673736
Old Sep 20, 2008 | 09:20 AM
StanNH's Avatar
StanNH
Originally Posted by BearZ06
Thanks, but that's not it. I should have been more clear...I get the three beeps, not honks, when I open the door to get in the car, not when exiting the car.
No problem with fob #1, just fob #2.
Old Sep 20, 2008 | 10:18 AM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Maybe its telling you the memory setting for fob 2 are not set? i.e. mirrors, seat position etc. Try programming your seat memory #2 and get the double beep - then see if it does it.
To be clear I'm assuming the beep is coming from the DIC - is there a message?
To Three beeps when opening door????
