qtp exaust cutout install switch problem
Old Sep 21, 2008 | 01:39 AM
NARIMAN's Avatar
NARIMAN
Default qtp exaust cutout install switch problem
i installed qtp exaust cutouts and it has electric switch
the sound is amazing from stock to cutouts open , it sounds like corvette should sound, much more fun to drive
i had exaust cutout on my previous car and the car felt much faster, now i feel the same it goes so much stronger, spinning wheels so much more then when closed.
i just have a problem the mechanik installed the switch and the light on the swtich is always on, even when i shut the car off. he did somthing wrong there i guess
i afraid it would kill my battery
is any one here knows what he should do to fix the problem?
the guy is not sure if there is another fuse box where he can connect to
i have same problem when i pluged my radar detector in sigaret lighter outlet it always stays on even when the car is shut off
WHY?
Old Sep 21, 2008 | 10:09 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
The problem is that there are very few switched power sources available. I wired my radar detector into the seat heater fuse and it is switched.
Old Sep 21, 2008 | 10:25 AM
microday's Avatar
microday
WHY?
Can someone explain more about these. I was considering a NPP exhaust with Mild-to-wild but this may be a cheaper option
Old Sep 21, 2008 | 11:51 AM
NARIMAN's Avatar
NARIMAN
so the problem that i have is normal?
Old Sep 21, 2008 | 09:20 PM
NARIMAN's Avatar
NARIMAN
i really need some suggestions please
Old Sep 23, 2008 | 01:18 PM
NARIMAN's Avatar
NARIMAN
how do you connect your radar detectors?
are they shutting off when the car is off, or they stay on all the time?
Old Sep 23, 2008 | 02:12 PM
dpigguy's Avatar
dpigguy
Your problem is the switch is fused through a curcuit that remains hot at all times just like the cigarette lighter. Suggest you have it wired to a curcuit that is not hot all the time such as the seat heaters or any other curcuit that is dead with the key in the off position. You can do that by tapping in to any such curcuit and putting a fuse between the tap and the switch to protect everything should the cut-out electrics draw too much current when activated. Same logic goes for the radar detector.
Old Sep 25, 2008 | 01:29 PM
NARIMAN's Avatar
NARIMAN
thanks
but do you think it can kill the battery the way it is now?
or i f i live the radar detector in the cigarette lighter on?
Old Sep 25, 2008 | 01:49 PM
RED2008Z06's Avatar
RED2008Z06
thanks
Yes, I would use the seat heater circuit like others have suggested...good luck
Old Sep 25, 2008 | 01:53 PM
C6Longshot's Avatar
C6Longshot
Any electrical device that constantly stays on is going to draw power from your battery. I would be worried as I have heard similar dead battery stories from others that do not run their vehicles on a frequent basis.
For you cutout switch, assuming it is only an LED indicator that remains energized, you are probably looking at minimal power draw- maybe close to what the blinking door lock LED's would generate.
Your radar detector would draw considerably more power.
If this is a DD, you might be able to get away with leaving these plugged in.
If you only drive the car once a week or so, I would definitely be worried.
Old Sep 25, 2008 | 02:27 PM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
I have been considering cutouts for my vette. I'm on the fence between QTP and DMH. What convinced you to choose the QTPs?
Old Sep 25, 2008 | 10:29 PM
0corvette pilot
Former Vendor
If you can use 3" cutouts, I have a set I will be selling soon, never installed. I have a custom welded exhaust and there just isn't room for them anywhere.
Old Sep 26, 2008 | 12:14 PM
NARIMAN's Avatar
NARIMAN
i got qtp because it was 315, cheaper then i found other brand sqare kind was over 400
they look very well build, the guy at exaust shop was amazed of the qlty.
i dont have a seat heater option, and i drive every day so i guess iwill be ok.
the sound is incredible when i shift at the red line from first to second it sounds like a gun shots, spins tire more then before, feels stronger for sure
BEST MOD for me
To qtp exaust cutout install switch problem
