Replacement Wiper Blades?
Sep 22, 2008 | 01:29 AM
The stock ones have that air deflector or whatever it is on them. Do you take that off or just put new wipers on and forget about that thing?
-David
Sep 22, 2008 | 01:39 AM
Quote:
Originally Posted by
NEV3R L8
-David
I replaced mine with Icons by Robert Bosch
Sep 22, 2008 | 02:08 AM
And you didn't worry about that wind deflector stuff on the factory ones? Just swapped 'em out right?
-David
Also do you know the sizes?
Sep 22, 2008 | 02:21 AM
Nevermind. I just found the part numbers for the Icon's. Driver's side: 421A Passenger side: 421B.
Sep 22, 2008 | 02:22 AM
Pretty sure only the driver's side blade has the wind deflector on it. You should be able to buy just the rubber blade. Then again, I'm new to the C6. Someone will correct me if I'm wrong. Not sure of the size. My C5 had the same size blades on each side.
Sep 22, 2008 | 04:58 AM
St. Jude Donor '12 thru '26
The entire Icon blade is a spoiler. Gene most likely has OEM blades if that's what you prefer
Sep 22, 2008 | 11:21 AM
No I'd rather have aftermarket I just wasn't sure how that was supposed to work. Thanks for the info. On my way to pick up the Icon's.
-David
Sep 22, 2008 | 11:27 AM
St. Jude Donor '05-'06-'07-'10
Sep 22, 2008 | 12:12 PM
I ordered mine from GM (local dealer) and they came without the air deflector!
NEV3R L8
-David
