Tires
Old Sep 26, 2008 | 04:41 PM
brunogangsta's Avatar
brunogangsta
Default Tires
Anybody know what could cause this to happen? This happened to my Right Front tire and my Left Rear tire. My tires are less than 6 months old. Thank God I wasn't going my usual 120mph! I contacted the manufacturer and the retailer too.
Old Sep 26, 2008 | 04:46 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Can't tell from here, but it looks like a defective tire. Hope no one waqs hurt.
Old Sep 26, 2008 | 04:51 PM
johnodrake's Avatar
johnodrake
Moderator
Hitting a pot hole will do it:
Old Sep 26, 2008 | 05:07 PM
Safe Guy's Avatar
Safe Guy
Running flat or seriously under inflated!
Old Sep 26, 2008 | 07:13 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
for the record, I'm a tire engineer in the U.S. Govt. working directly with NHTSA on a constant basis.....I ran the Federal Tire Qualification Program for 13 years....and have done a ton of tire failure analysis... some of which was used in litigation..... if you have taken proper care of your tires, you need to go to NHTSA's site and fill out a defects report.
That is the classic belt edge separation. Causes: running excessive speeds under inflated (too much heat generation). Racing on road course tracks under inflated or to extreme.....or defect in the tire. I can see you have worn down the tread surface pretty good. that one crown edge where the failure occurred is very worn...
a "zipper" begins and the belt edge unzips...
as stated above, hitting a huge pot hole the right diameter will also cause this separation.. it compresses the casing structure beyond its limits and the weakest point is the edge of the belt package...especially in a non speed rated tire which has no belt edge wedge supports, which high performance tire utilize.
What brand designation was those tires? what psi were you running?
Old Sep 26, 2008 | 10:18 PM
c6 batmobile's Avatar
c6 batmobile
Holy crap. That was rough Im glad you were alright.
Old Sep 26, 2008 | 10:34 PM
From C6ZO62C8's Avatar
From C6ZO62C8
wow, good thing your weren't hurt, and that's why as much as I hate the traction, I'm sticking with run flats
Old Sep 26, 2008 | 10:42 PM
Tom_Slick's Avatar
Tom_Slick
Bruno, haven't heard from you in awhile... Sorry to hear about the tire problem. Ever get the bumper removed/ painted?
Old Sep 26, 2008 | 11:04 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Ouch!
Old Sep 27, 2008 | 06:12 AM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Here's an example of a "zipper" for ya'll on a Pirelli P-Zero Corsa
And I wasn't doing 120, I was hitting 140 on the front straight
Fortunately I caught it before it turned into that \/\/\/\/
Originally Posted by brunogangsta
Old Sep 28, 2008 | 10:09 AM
brunogangsta
Now earlier that day I was hitting 150mph going to Effingham. I check my tire pressure everytime I take the car out! My thing is that They are Z rated tires. They should handle that speed with no problem. No pot holes though. On the rear tire I was rolling too but whats the purpose of having these Nitto 555 and they can't take the beating. Any suggestions on another brand tire?
To Tires
