Clutch feels different??? Need Help!!
Old Sep 26, 2008 | 07:05 PM
CP3's Avatar
CP3
Default Clutch feels different??? Need Help!!
Ok I got my headers installed yesterday locally from a reputable shop which deals with vettes exclusively, and after the install of the headers soon as I drove off my clutch felt different. I noticed it right away, and took my car back there today to make sure everything was ok underneath.....seems fine...
Question is why does my clutch not feel springy anymore, feels really spongey. it feels more rough, not smooth and almost feels like I got to press down harder with my foot, no bounce to it......Thats the best way I can describe it. I know anytime you make/do mods your car is going to feel different but why does my clutch feel different if they never even touched it or did any work to it?
When I got my B&B fusions installed earlier this year this never happened....need help? What should I do?
thnx guys
Old Sep 26, 2008 | 07:06 PM
CP3's Avatar
CP3
PS. I got my brake fluid checked it was fine and tranny fluid everything seemed fine under the hood.... and its a stock oem clutch not aftermarket or nething..
Old Sep 26, 2008 | 07:20 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Headers really heat up your fluid which makes the clutch feel worse... one of the downsides. Wrap all your clutch lines in DEI cool tape and swap your fluid for something with a higher temp threshold. Also, suck out the reservior and replace w/ fresh fluid every couple of weeks.
Old Sep 26, 2008 | 07:38 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
good point above! also, are your headers coated at all? if not, probably some of the heat is not being contained.
Old Sep 26, 2008 | 08:01 PM
Vet's Avatar
Vet
If the degraded clutch feel was purely a function of high heat from the headers, wouldn't the clutch then feel "good" for say the first 15 minutes after a cold start before the clutch system has had time to "overheat"? Or perhaps everything "overheats" almost instantly? Sounds like a very noticeable change in clutch feel... not good. Is this a common observation by those who install headers?
Old Sep 26, 2008 | 08:04 PM
Cobra4B's Avatar
Cobra4B
It's pretty common... many don't say anything. I started having stickey pedal problems with my car at the track (track = road course) after putting headers in. I ended up having my headers ceramic coated with 2000 degree "turbo black" coating, wrapped all clutch lines with heat reflective tape, and upgraded to ATE superblue in the hydraulics.
Clutch works now, but no nearly as well as my father's '04 w/ stock exhaust etc.
CP3's Avatar
CP3
I noticed it right away when I started up the car.... and it hasn't gone away since....Even this morning when I started it up in the cold same thing.... :S
Old Sep 26, 2008 | 08:07 PM
CP3's Avatar
CP3
Also my malfunction.... check engine light came on the dashboard this afternoon....Im assuming b/c of no cats (off road) ??
Is this something to worry about?? How can I get rid of it if I need to other than putting on aftermarket cats or dummy cats....
Thanks in advance..
Old Sep 26, 2008 | 08:09 PM
Cobra4B's Avatar
Cobra4B
^ You need to get the car tuned and have them turn the rear O2s off. That will stop you from throwing codes. The car sees the increased flow as a malfunctioning cat because it is getting readings outside of it's "ok" threshold.
Will it hurt anything? No... but if you live in a state where they plug into the OBD to do your state inspection you'll come up with a "not ready" status and they won't be able to inspect you car. The car must go throuh a certain amount of drive cycles to achieve "ready status" on all of it's systems. When you reset a code those affected systems go to "not ready".
Old Sep 26, 2008 | 08:11 PM
Cobra4B's Avatar
Cobra4B
Well ask them if they disconnected the clutch line... you could have air in the system if they did. That said, there's no reason to disconnect the line when doing a header install.
The car won't be funky when hot only, as the fluid gets hot it degrades and needs to be freshened up religiously.
Most C5/C6 drag racers suck out the reservior and refill it every week as a bandaid. The actualy bleed screw for the clutch hydraulic system is only accessible by removing the center section of the exhaust and the tunnel plate.
This is why most people who get a clutch put in their cars go ahead and get a remote bleed line which moves your bleeder into the engine bay area.
Old Sep 26, 2008 | 08:12 PM
CP3's Avatar
CP3
thanks cobra4b !!
Cheers!
To Clutch feels different??? Need Help!!
