hello??
Old Sep 27, 2008 | 07:36 PM
THERETURN's Avatar
THERETURN
Default hello??
hello everyone im having a issue with my z is very wierd when i shift it feels the clucth has a sligth delay before it engages this only A W.O.T??? any suggestion would be greatly appreciated?? thanks in advance guys
Old Sep 27, 2008 | 07:48 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Did you buy the car used? The clutch could simply be starting to wear. You might start with changing out the clutch fluid.
Old Sep 27, 2008 | 08:08 PM
THERETURN's Avatar
THERETURN
but the clucth does not spin, is just that slight delay
Old Sep 27, 2008 | 08:21 PM
THERETURN's Avatar
THERETURN
The weird part is that i dont smell clucth what so ever??
Old Sep 27, 2008 | 08:22 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
try this Ranger's clutch thread.
http://forums.corvetteforum.com/show....php?t=1325077
Also try not to drive that Z so hard... Its very delicate and sensitive.
Old Sep 27, 2008 | 08:32 PM
dpigguy's Avatar
dpigguy
when this happens, watch your tach and see if rpms are increasing and then coming back down. you may have a clutch thats worn and slips even though you don't feel or smell anything. the tach can help you see if that is occurring. check to see that the clutch is coming up fully as well. if not, change the fluid and see if that helps. also make sure that if its only at WOT you are just not experiencing wheel spin.
Old Sep 27, 2008 | 09:56 PM
danl72's Avatar
danl72
Old Sep 27, 2008 | 09:58 PM
VET4LES's Avatar
VET4LES
Old Sep 27, 2008 | 11:00 PM
THERETURN's Avatar
THERETURN
Originally Posted by VET4LES
I just changed the fluid ok guys i just drove the car. I started in 2nd at 35Mph and i stomp it on but i felt it little slow and then my rev limiter kicked in at 6500??? I may want to add that my tires are kinda worn?? after i did another in
2nd at 50mph gradually got on throttle then when went on and it took it 7000rpm and it pull hard?? I got out the car tried to smell for the horrible smell of burnt clucth but nothing?????
Old Sep 28, 2008 | 12:43 AM
THERETURN's Avatar
THERETURN
could it be the clucth master Cy going bad??
To hello??
