Carpet Replacement
Old Sep 29, 2008 | 10:40 PM
hyperjoe's Avatar
hyperjoe
Default Carpet Replacement
Does anyone know if any tools are required to replace the rear carpet and one of the cubby hole containers?
Thanks!!
Old Sep 30, 2008 | 12:00 AM
1Day's Avatar
1Day
Old Sep 30, 2008 | 12:15 AM
MARSC6's Avatar
MARSC6
I have pulled up about half the rear carpet for an install I did. I just had to pull it out from under the trim pieces. There was nothing I encountered holding it down. Just watch the carpet doesn't kink and deform the backing. The two covers for the stowed roof panel hooks just pop off if you pull straight up. The only part I didn't have pulled up was the very back because I had no need. But if any trim panels need to come off everything seems to be held to together with clips and plastic pins.
Old Sep 30, 2008 | 01:21 PM
hyperjoe's Avatar
hyperjoe
Thanks for the tips...
To Carpet Replacement
