Winter Prep
From what I've read so far here is what I've come up with for storage (someone correct me if I am wrong on anything).
1. Change oil in the car before storage
2. Add fuel stabilizer to the gas tank and run the engine before storage
3. Put the battery on a tender or remove it from the vehicle and store it in a warm place
4. Inflate wheels to 40 psi
5. Place the wheels on something other than concrete, carpet pads work good.
6. Invest in a good cover to keep the dust off
Other things people do (which I've never gotten a clear answer on) are:
1. Plug exhaust holes
2. Jack up the car to unload the suspension
3. Don't engage the parking brake or leave the car in gear.
Feel free to suggest additons, subtractions and corrections. Thanks.
4. Place the wheels on something other than concrete, carpet pads work good.
5. Invest in a good cover to keep the dust off
40psi in the tires(lower to 30 before the first drive next spring)
Put dryer softener sheets(Bounce) in aluminum pie pans and place in the cabin. Put sheets around in the engine compartment, and stuff sheets in exhaust tips.
I think you've pretty much got it though. I could see jacking up the car to unload the suspension but probably more so to keep the tires from going out of round, although the 40psi would prob. do the same thing.
I just do as an earlier poster suggested and fill the tires to the max psi stated on the sidewall and have not had any problem with flatspotting.
I also hook up a Battery Tender to keep the battery in good shape.
