View Poll Results: Please select yes or no if you have replaced your damaged front air dam.
Yes
17
10.18%
No
136
81.44%
No, but the air dam needs replacing
14
8.38%
Voters: 167. You may not vote on this poll
Poll
Old Oct 9, 2008 | 10:24 AM
RadarP3C's Avatar
RadarP3C
Default Poll
There are a lot of threads on the subject of the front air dam scraping driveways, speedbumps, etc., and the relatively low cost of replacement. But I've never seen a post of someone actually replacing the front air dam.
Just curious of how many folks have replaced theirs for one reason or another.
I'll start. My left side section is damaged, but I haven't replaced it yet.
Old Oct 9, 2008 | 10:33 AM
mksz51's Avatar
mksz51
When I purchased my car used about 1 year ago the left side section was a bit askew. I was able to unbolt that section, straighten a mounting bracket, and reassemble with new plastic hardware and it's been fine since. Normal day to day "rubbing" over driveway entrances, etc. will scrape the bottom edge but not cause significant damage. I think it takes a pretty good hit (which is easy enough since the air dam rides so low) to actually cause real damage. Often that can be repaired easily, however.
Old Oct 9, 2008 | 10:39 AM
StanNH's Avatar
StanNH
You really should have put a more meaningful title on this post. "Poll" doesn't really tell the readers anything.
Old Oct 9, 2008 | 10:42 AM
RadarP3C's Avatar
RadarP3C
Thanks, Stan. I thought about that, but if you roll your cursor over the title, you will see the first sentence of the thread and have an ideal of what the poll is for....
Old Oct 9, 2008 | 10:43 AM
vettedoogie's Avatar
vettedoogie
Yes..."Poll" is pretty ambivilent.
Old Oct 9, 2008 | 10:49 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
replaced the ones on the C5 3 times.. cost $13.00 a side
Old Oct 9, 2008 | 11:49 AM
EvanD's Avatar
EvanD
CF Community Team
Replaced my C4 dam many times, cheap and easy, I always kept one in stock "in case".
Old Oct 9, 2008 | 11:52 AM
70454's Avatar
70454
Mine is becoming 'furry" from wear.
I bought two complete spares from Gene. They're hanging around my garage.
PO10TIAL's Avatar
PO10TIAL
It scrapes all the time in the same spots but Ive never replaced it.....you adjust the way you take the inclines
Old Oct 9, 2008 | 12:00 PM
Gordon Shumway's Avatar
Gordon Shumway
Replaced the right front when I inadvertently ran up on a high parking bumper (diagonal parking spot). It didn't feel that bad, but it pushed the air dam and lower extension piece back into the wheel well liner cracking the liner in three places. The air dam piece was pretty beat up and somewhat twisted at that point, so I replaced it along with the other pieces. I think it was $14 and change.
Old Oct 9, 2008 | 12:09 PM
STEVE MC's Avatar
STEVE MC
Mine scrapes exiting my driveway unless I take a sharp angle as I pull out. Pulling in is not a problem provided I go real slow.
So far so good, haven't replaced mine yet.
Old Oct 9, 2008 | 12:47 PM
dvilin's Avatar
dvilin
Mine scraped on the driverway the first few times after I bought the car but quickly learned to pull out at an extreme angle with no problems, have not had any scrape type issues since, so no damage no need to replace.
Old Oct 9, 2008 | 02:23 PM
BigJoe's Avatar
BigJoe
When new mine scraped badly everytime I left my driveway. Now after 3 years it doesn't scrape nearly as much. Probably because it is worn down where it used to scrape. I don't notice that it looks bad and I'm sure if I don't notice no one else will either...
If it get so short it starts to affect cooling, assuming it is like the C5's dams that are actually a part of the cooling system, I'll break down and replace it. Until then, meh...
Old Oct 9, 2008 | 02:27 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Old Oct 9, 2008 | 03:15 PM
LisasZR1's Avatar
LisasZR1
Lifetime NCM Member #2482
St. Jude Donor '11
Replaced mine after I ran over a racoon.
Old Oct 9, 2008 | 03:21 PM
VET4LES's Avatar
VET4LES
Mine scrapes every time I drive in and out of my driveway. It's been over three years and it doesn't need to be replaced yet. It's doing it's job by swinging back and forth when it scrapes.
Old Oct 9, 2008 | 03:22 PM
Harley06's Avatar
Harley06
To Poll
Old Oct 9, 2008 | 03:28 PM
T Will's Avatar
T Will
St. Jude Donor '13-'14-'15-'16-'17-'18-'19
Three vettes never replaced one.
Old Oct 9, 2008 | 03:32 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
had lots of low cars over the years... you learn not to scrape... i know...sometimes you cant avoid it, but in most cases, you can.
Old Oct 9, 2008 | 08:32 PM
RadarP3C's Avatar
RadarP3C
Yes 11.71%
No 79.28%
No, but the air dam needs replacing 9.01%
Wow, I’m glad my livelihood doesn’t depend on replacement air dam sales…
