Engine Light
Old Oct 11, 2008 | 08:31 PM
Dan Seagate's Avatar
Dan Seagate
Default Engine Light
Took the C6 (2006 8500 miles) out for a drive today in the Boston area and sometime during the trip I noticed the engine light had illuminated. All the gauges looked fine, engine temp. oil pressure etc. Do you think this is tied to the gas cap that I know needs to be replaced but my dealer didn't have one when I went in a few weeks ago.
What are the most common triggers for that warning?
Old Oct 11, 2008 | 09:04 PM
DJackman's Avatar
DJackman
If you car is stock, Im willing to bet it has something to do with your gas cap. Make sure its closed properly.
Old Oct 11, 2008 | 10:16 PM
MJDVET111's Avatar
MJDVET111
Yes a loose gas cap could trip the CE light. Sounds like you already know your gas cap is bad? So a good bet that's the reason. But CE light could be for any number of things (MAF, O2 sensors, misfire, etc) Most all related to emissions and things like that. If the condition that caused the CE light no longer exists the next time the OBDC runs the diagnostic check, the computer should clear it and light will go out.
Old Oct 11, 2008 | 10:28 PM
ProgGod's Avatar
ProgGod
Most likely either emissions or engine running rich, etc..
Have the dealer pull the code, or find someone with an ODB reader.
Old Oct 11, 2008 | 10:29 PM
budgreen3564's Avatar
budgreen3564
it happens alot with these cars. they're pretty cheap, so i just buy a new one when needed. i want to say $17 from chevy
To Engine Light
