Engine Temperature
Old Oct 13, 2008 | 09:22 PM
antt's Avatar
antt
Default Engine Temperature
This past weekend was the my first time in serious traffic, and the engine temperature increased to 220degF, while the transmission temperature increase to 203degF. I pulled over to check under the hood and the radiator fan did not appear to be running or could not be heard over the engine noise.
What is the temperature setpoint that should actuate the fan, and shouldn't the fan run when the AC is on regardless of engine temperature? What is the a normal engine temperature range, and will the 203degF transmission temperature cause damage?
Old Oct 13, 2008 | 09:30 PM
shopdog's Avatar
shopdog
220F is not excessive in a traffic jam. The fan should be running, but not very hard. It doesn't go to 90% speed until temperature reaches 230F. Transmission temperature of 203F is no concern at all.
Old Oct 13, 2008 | 09:42 PM
cmonkey713's Avatar
cmonkey713
I agree with Shopdog that 220 is not excessive. It really gets hot here in Oklahoma and I would run about 220 to 225 in heavy trafic or in parades in the summer. When I added the longtubes and CAI I installed a 160 thermostat. I had a dyno tune to get everything in harmony. Never gets over about 190 even on the hottest 108 summer days. Usually runs about 180 in normal outside air temp. I feel better just looking at the temp gage. The stat is about $15 to $20 and takes about an hour to install. Worked for me.
Old Oct 13, 2008 | 09:44 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Oct 13, 2008 | 09:45 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
I had about the same temps one day at the Eureka Springs weekend a couple years back. Onstar connected me to the closest Chevy dealer
(where we have the AutoCross). They said that was not excessive, and if there was any problem, I'd get a warning on the DIC. It didn't cause any problems, even though I thought it was high.
Old Oct 13, 2008 | 10:02 PM
spinalator's Avatar
spinalator
Old Oct 13, 2008 | 10:05 PM
antt's Avatar
antt
Does the fan run when the AC is on, even if the engine temperature is OK. Should the fan be heard over the engine noise?
On every other vehicle I've had with an electric fan, the fan noise could be easily heard over the engine noise.
Old Oct 13, 2008 | 10:12 PM
shopdog's Avatar
shopdog
The fan isn't loud. I can hear it echoing off the wall at the fast food drive thru with the window down the radio off, and engine at idle. With the windows up, or with the radio on, or at any engine speed other than idle, you can't hear the fan from the driver's seat.
Old Oct 13, 2008 | 10:20 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Normal for engine temp, don't know the auto temp, but it is less than the engine so sound OK.
Old Oct 13, 2008 | 10:25 PM
antt's Avatar
antt
I guess I'll have to take the car to the dealer. At the 220degF coolant temperature, I couldn't hear the fan or feel air movement at a point in front of the passenger side cylinder head.
To Engine Temperature
